Transmission fluid only leaks while driving! - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 07-16-2010, 11:50 AM   #1
absolutGS-T
1998 Eclipse GST-X
absolutGS-T's Gallery
Hey guys Ive been having this weird problem. There is transmission/transfer case fluid leaking but only when im driving. If I let my car sit over-night it doesn't leak at all. It seems to be dripping down off of the transfer case. So I don't know if it is dripping down to it or not. Ive checked both of the fluid levels in the transmission and transfer case and they are both fine. Could it be axle seals?
Thanks
Dave
absolutGS-T is offline   Reply With Quote
Old 07-16-2010, 12:00 PM   #2
shadohc
DSMtalker
Eagle Talon 1995
shadohc's Gallery
Feedback Score: 2 reviews
Re: Transmission fluid only leaks while driving!
I would say it is a axle seal mine was leaking before and i put a new one in with thin plastic washers behind it on the drivers side if that is where yours could be leaking but it fixed my problem. I got them john at ipt because i kept replacing seals
shadohc is offline   Reply With Quote
Old 07-16-2010, 02:43 PM   #3
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
Feedback Score: 9 reviews
It could also be the transfer case input seal leaking...
10HR OPR BSMR NAFPR
DSM Loki is offline   Reply With Quote
Old 07-16-2010, 05:44 PM   #4
absolutGS-T
1998 Eclipse GST-X
I've narrowed it down some. Its leaking in between the transmission and transfer case. I haven't been able to put it on the lift to check it out but I am going to do that tomorrow.
Thanks
Dave
Old 07-16-2010, 11:41 PM   #5
bertrenolds5
Hardcore DSMtalker
bertrenolds5's Avatar
91 Eagle Talon TSI GST
bertrenolds5's Gallery
Sounds like a seal and alot of fun and work!
bertrenolds5 is offline   Reply With Quote
Old 07-20-2010, 08:10 AM   #6
mshowe0827
Eclipse GST 1995
mshowe0827's Gallery
I have been having the same problem with mine. I was told that it was leaking from the axle seal...so my plan is to start working on the repairs this weekend hopefully!
mshowe0827 is offline   Reply With Quote
Old 07-20-2010, 09:55 AM   #7
absolutGS-T
1998 Eclipse GST-X
I just finished doing my axle seal this morning. AWD driverside seals are a real pain. When my car was a gs-t it was as easy as pulling the axle pretty much but with the AWD I actually had to pull the transfercase because I couldnt reach around it to pull the seal off.
Old 12-04-2010, 01:25 PM   #8
SmokinV8's
Super DSMtalker
Grand Cherokee Limited
SmokinV8's's Gallery
Did this fix your issue? I'm having the same problem but its still happening to me after new seals. My issues started as just a small leak after driving it too. I last drove it 3 weeks ago and parked it on a big piece of card board so I can see the leak. I checked it for 2 weeks straight while it was sitting and it didn't leak anymore than the few little drips after my last drive. Sometime over the last week though the leaks gotten much bigger even though it hasn't been driven in weeks. I just did a tranny fluid change so my fluid is nice and clean which makes it really tough to follow the leak trail.
94 Talon TSi
SmokinV8's is offline   Reply With Quote
Old 12-09-2010, 03:48 PM   #9
absolutGS-T
1998 Eclipse GST-X
Is it your Driver side or passenger side axle seal thats leaking?
Old 12-09-2010, 04:00 PM   #10
SmokinV8's
Super DSMtalker
Its the passenger side. I pulled the battery out and took a good look down at the axle and I'm pretty sure its the axle seal thats leaking. I talked to a few local dsmer's and since the seal is new they think I need to clean up the axle itself to make a better seal. It makes sense cause I was worrying so much about putting the seal in straight and lubing it so I didn't tear it when putting the axle in I totally over looked the axle itself. I ordered another new oem seal and I'm going to clean up the axle with a scotchbrite pad and hopefully that takes care of it. It wouldnt surprise me if my axle developed a touch of surface rust while it sat with no tranny for 2 months.
94 Talon TSi
Old 12-20-2010, 01:14 AM   #11
spyder96
spyder96's Avatar
Mitsubishi/Eclipse/1996
spyder96's Gallery
input shaft seal a big 4 dollar seal that requires the tranny to be pulled to replace, that is if it only leaks while driving, funnnn
spyder96 is offline   Reply With Quote
Old 12-20-2010, 01:20 PM   #12
SmokinV8's
Super DSMtalker
I replaced the input shaft seal with a brand new oem mitsu one before I put the tranny in. I'm pretty certain its my axle seal. I've got a new oem one I'm just waiting for the temps to get up into the 30's so I can change it cause I don't have a garage.
94 Talon TSi
Old 12-20-2010, 09:30 PM   #13
Stephen
Senior Moderator
Stephen's Avatar
1995 Talon TSi AWD
Stephen's Gallery
You're bringing back memories... bad ones.
Stephen is offline   Reply With Quote
Old 01-21-2011, 08:28 AM   #14
SmokinV8's
Super DSMtalker
Just thought I'd share my info. Upon pulling out my leaky axle I noticed that there was a very light discolored ring around the axle where the seal sits on. I took some fine grit sand paper and polished it till the discoloration was gone. I found a nice tip here on the forums about an easy way to get the seal in evenly while the tranny was still in the car. I slide the new oem axle seal over the axle and then gently worked it into the tranny with it already seated on the axle. It worked like a charm its been about month since I replaced it and its leak free
94 Talon TSi
