J pipe leaking fix and turbo banjo bolt replacement - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Notices
Old 08-23-2010, 02:27 PM   #1
spyder79
Hardcore DSMtalker
spyder79's Avatar
1997 Eclipse GST Spyder
spyder79's Gallery
Feedback Score: 10 reviews
I cannot get my j-pipe on my 16g to stop leaking! I used the gasket and used sealant as well and it still leaked when I was doing my BLT. How do you guys seal these? Do I need to use more rtv sealant? Also I have to replace the oil feed line bango bolt on my 16g. You guys think this can be done without taking the turbo off? See the pic below. It looks like a tigth fit. Not sure if I can do it with the turbo still on the car. I can take off the heat shield, but I think the exhaust manifold might be in the way. What do you think?
spyder79 is offline   Reply With Quote
Old 08-23-2010, 05:10 PM   #2
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
Feedback Score: 9 reviews
Re: J pipe leaking fix and turbo banjo bolt replacement
Drop the turbo, it isn't worth the frustration to try to keep the turbo up there.
10HR OPR BSMR NAFPR
DSM Loki is offline   Reply With Quote
Old 08-23-2010, 06:41 PM   #3
DSM4LIFE-AWD
Ultra DSMtalker
DSM4LIFE-AWD's Avatar
GSR-4 1991, TSiAWD 1995
DSM4LIFE-AWD's Gallery
Feedback Score: 3 reviews
Hey spyder, why the f**k did you put thread sealant on a JIC or AN fitting ? Dont ask why it leak ... Read this and learn http://www.dsmtalk.com/forums/showth...95#post2222995
DSM CaN MaKe DReaMS CoMe TRue --> My 95 BuiLD THReaD and My 91 BuiLD THReaD
2009= 8.55 @1/8 Mile - TSi AWD 1995
2011= 8.93 @1/8 Mile - GSR-4 1991
DSM4LIFE-AWD is offline   Reply With Quote
Old 08-23-2010, 06:49 PM   #4
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
Reading is hard, especially when they're instructions.
10HR OPR BSMR NAFPR
Old 08-23-2010, 07:01 PM   #5
spyder79
Hardcore DSMtalker
spyder79's Avatar
spyder79's Gallery
That is not were it is leaking. Its leaking where the stainless steel hose turns into a hard pipe. But your right, I shouldn't have used tephlon tape. I realized what I did awhile back but it wasn't leaking and never has so I was going to correct it next time I puller my Turbo.
Old 08-23-2010, 07:14 PM   #6
Red1991TSI
Site Administrator
Red1991TSI's Avatar
1991 Eagle Talon Tsi
Red1991TSI's Gallery
Feedback Score: 78 reviews
For the J-pipe, are you sure you have that weird bracket out of the way? I've seen others who get it trapped under the flange of the pipe and it will NEVER seal like that.
Read the rules people!
Red1991TSI is offline   Reply With Quote
Old 08-23-2010, 08:41 PM   #7
spyder79
Hardcore DSMtalker
spyder79's Avatar
spyder79's Gallery
Weird bracket? The only thing close to it is the heat sheild. My other j pipe had a leak too. Do you guys use rvt sealant or just the gasket by itself?
Old 08-23-2010, 09:01 PM   #8
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
Use some copper rtv on the gasket, but make sure you actually follow the directions on the rtv.
10HR OPR BSMR NAFPR
Old 08-23-2010, 09:22 PM   #9
19GSX97
Hardcore DSMtalker
19GSX97's Avatar
08 Evo X GSR
19GSX97's Gallery
Feedback Score: 16 reviews
I hear your supposed to let the rtv sit on the gasket for like 10 mins then put the gasket where it needs to be and tighten it up.
08 EVO X GSR
-Jon
19GSX97 is offline   Reply With Quote
Old 08-23-2010, 09:40 PM   #10
DSM4LIFE-AWD
Ultra DSMtalker
I have read that too but all my friends who work in mechanic told me the opposite. I also had success not waiting 10 min.
Maybe your flange on the j-pipe is not flat enough ... Check it with a ruler or a flat surface.
Old 08-23-2010, 11:45 PM   #11
Red1991TSI
Site Administrator
Red1991TSI's Avatar
There is a bracket which goes to one of the coolant lines or something. Usually bolts under the farthest bolt hole. You may or may not still have it on there. I've seen people forget it is there and bolt it under the J-pipe by accident instead of on top.
Old 08-24-2010, 12:46 AM   #12
williillii
DSMtalker
williillii's Avatar
1995 Eclipse Gst
williillii's Gallery
For the banjo bolt...I couldnt fit my wrench on there with the radiator installed. So I took a 19mm (whatever the bolt is, think its 19) socket and a 12mm bolt and nut. Put the bolt through the socket where the ratchet goes with the head sticking out the top. Tighten the nut down on the inside with some needlenose pliers or something. Now you can use a smaller 12mm wrench to break the banjo free and then just spin it out by hand.
Thats what I did anyway, didnt feel like dropping the turbo.
williillii is offline   Reply With Quote
Old 08-24-2010, 01:29 AM   #13
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
You can also buy a socket that has a hex forged into the outside and use a wrench on it. I thought my snapon guy was a dick trying to push them onto me, until I needed one.
10HR OPR BSMR NAFPR
Old 08-24-2010, 06:38 AM   #14
spyder79
Hardcore DSMtalker
spyder79's Avatar
spyder79's Gallery
Thanks for the help. I will check to see if that flange is flat. That sounds like it could be the problem. I guess my other one was not flat as well. Yeah, I didn't feel like dropping the turbo either because I only have an hour to change the oil and the line, so hopfully nothing else goes wrong. When I started my car and the oil started puring out I did get a P0110 and P0105 CEL for some weird reason. That has never come on before. Its the baro pressure sensor and IAT sensor. Sounds like my MAF somehow got messed up, but at the time I didn't have my couping tightened down at the turbo and air intake. Not sure if thats why it came on. I will clear it with link and see if it comes back on. Thanks again for the help.
Old 08-24-2010, 06:08 PM   #15
spyder79
Hardcore DSMtalker
spyder79's Avatar
spyder79's Gallery
Just wanted to say thanks for the help. I was able to get the line off and put the new one on. Thanks for the tip on the AN fittings. I take it once it starts to move the line with it than its tight. It doesn't leak so I must have tighten it down enough.
