Eagle talon won't start! - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 10-13-2010, 08:14 PM   #1
96DSMOwner
1996 Eagle Talon Tsi AW
96DSMOwner's Gallery
Exclamation Eagle talon won't start!
Ok I can't figure out why my engine won't start in my 96 tsi. It will crank but not start. I have spark, fuel in and out, timing, and compression. The engine almost has to start. But it will not. It just cranks like it's having trouble. My buddy checked the injectors and they were good. But I think the engines getting flooded because I pulled out a plug after turning it a few times and it was pretty wet in gas. If my crank sensor was bad I wouldn't have spark right? Or could it be my fuel temp sensor? I'm kinda stumped. Also I should note I swapped the engine and it's a 7 bolt 2gb if this helps
96DSMOwner is offline   Reply With Quote
Old 10-18-2010, 09:57 PM   #2
89142
89142's Avatar
89142's Gallery
Re: Eagle talon won't start!
Mine done this was crank and cam could just be cam. Also if u have plug wires I had one set that just went bad car would crank and crank but not fire. Was getting spark not enough look for the color of the spark.
89142 is offline   Reply With Quote
Old 10-18-2010, 10:03 PM   #3
HOT97ECLIPSEGSX
Site Administrator
HOT97ECLIPSEGSX's Avatar
1997 Mitsu Eclipse GSX
HOT97ECLIPSEGSX's Gallery
Feedback Score: 27 reviews
You are 100% sure you have:
1. Fuel at the fuel rail, and good fuel pressure
2. Spark (put a spark plug in the wire and try and turn it over)
3. Good compression (what are your numbers)
4. Timing lined up perfectly?
- Dustin
DSMtalk Rules and FAQ!!
1997 Mitsubishi Eclipse GSX - 12.281 @ 115.85 MPH (KCIR) - Weekend Terrorizor
2012 Subaru Impreza Limited AWD - The Daily
HOT97ECLIPSEGSX is offline   Reply With Quote
Old 10-18-2010, 10:47 PM   #4
DSMvert
DSMvert's Avatar
96 Talon TSI AWD
DSMvert's Gallery
This might be a long shot, but I had my ground burn out on my ECU and that's what mine did. Here's the description:
http://www.ecmtuning.com/wiki/blowns...round?s=ground
DSMvert is offline   Reply With Quote
Old 11-05-2010, 01:21 PM   #5
motozachl
DSMtalker
motozachl's Avatar
'97 Eagle Talon TSI AWD
motozachl's Gallery
Feedback Score: 2 reviews
check the ecu for leaky caps, go back over all your connections, spray some starter fluid in the intake
motozachl is offline   Reply With Quote
Old 11-09-2010, 10:57 AM   #6
SLEEPS
Ultra DSMtalker
SLEEPS's Avatar
93 D21 beater
SLEEPS's Gallery
Feedback Score: 3 reviews
He has fuel, why would he use starter fluid? Half of your post seem to be random nonsense. Do you read the previous posts? Oh, and check rule #7 again, over and over...
2015 Sorento GDi. 1993 D21 beater.
Originally Posted by LandoAWD View Post
Forum users are generally idiots.
SLEEPS is offline   Reply With Quote
Old 11-09-2010, 11:01 AM   #7
Gray91GSX
Hardcore DSMtalker
Gray91GSX's Avatar
1998 Eclipse Spyder
Gray91GSX's Gallery
Feedback Score: 6 reviews
Check your resistor pack to see if its in spec, mine would flood out of my engine, I had spark and fuel, but it would not fire, and when I pulled the plugs they would be covered with gas. Its worth a check.
91 GSX- Shell sold to Cory
93 Laser- Got from Cory
96 Spyder- Traded the $1 Laser for it
98 Spyder- Traded Prelude and Cavalier for
Gray91GSX is offline   Reply With Quote
