Rear motor mount snaped - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Suspension and Handling Tech
Old 01-08-2011, 07:50 PM   #1
chrit
chrit's Avatar
95 eclipse
chrit's Gallery
Ive snaped my rear motor mount as u can read the title, i think i can handle changing it my self, but i wanted to ask first befor doing it i know i have to lift the car up put it on jack stands and then lift the motor up and get a 17mm socket for the motor mount its self. my mechanic wants 400$ to change it so im wondering if theres more to it then just lifting the motor and unbolting it and putting the new one on. thanks again
chrit is offline   Reply With Quote
Old 01-08-2011, 07:58 PM   #2
dsmchris27
DSMtalker
dsmchris27's Avatar
1990 Eagle Talon TSi
dsmchris27's Gallery
Re: Rear motor mount snaped
Not really much to it, just getting to it which is the hard part. Support the engine with a jack and block of wood and then get busy. It may make it easier to remove some stuff thats in your way like the upper intercooler pipe or cold pipe, should make it a little bit easier.
dsmchris27 is offline   Reply With Quote
Old 01-08-2011, 10:19 PM   #3
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
You shouldnt even have to jack anything up, just pull the bolts out and remove it.
Old 01-09-2011, 08:15 PM   #4
chrit
chrit's Avatar
95 eclipse
chrit's Gallery
Could i just jack up the motor without lifting the car itsself? and is it eacyer going at it from the bottom or top?
Old 01-09-2011, 10:29 PM   #5
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
I remove the battery and battery tray and do them right from the top, put a jack under the pan (with a block of wood on the jack to avoid denting the pan) and start loosening the mount bolt that goes through the center of the mount, if resistance is found when you try to slide the bolt out then put pressure on the jack or remove it until the bolt slides right out without any tension on it, after that remove the other mount bolts and pivot the mount right up and out of there.
Old 01-09-2011, 11:32 PM   #6
FugitivE
DSMtalker
FugitivE's Avatar
95 Talon TSi FWD AT
FugitivE's Gallery
Feedback Score: 3 reviews
If you really want easy access to the mount, just remove the head. Then you can lean right in there with plenty of elbow room.
You shouldn't need to jack the engine until your trying to line the bolts up. The other 3 mounts will hold the engine until the new mount is in. That's what I did for mine. Only lifted engine to put the center bolt in.
FugitivE is offline   Reply With Quote
Old 01-10-2011, 12:19 AM   #7
theblizz
Super DSMtalker
theblizz's Avatar
90 GSX
theblizz's Gallery
Feedback Score: 1 reviews
Removing the head or intake manifold is just silly, if all your doing is changing a motor mount.
Also, How did you snap a motor mount? I've never heard of this happening.
Like stated before, removing the battery and charge piping will give you plenty of room to get to the mount from inside the engine bay. No need to lift the car since the motor mount is ontop of the subframe, Not accessable from the bottom.
Good luck.
theblizz is offline   Reply With Quote
Old 01-10-2011, 06:08 AM   #8
chrit
chrit's Avatar
95 eclipse
chrit's Gallery
I may be mistaking on what motor mount i snaped, the motor mount i snaped is the one behind the motor when u open ur hood and the cams are on the right side, and idk how i snaped it i was told my car has to much power for the oem motor mounts but thats just silly, i wish that could be true my guess is it just rotted out and one day i shifted hard and it snaped.
