Replacement shift solenoids - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 02-10-2011, 10:30 PM   #1
y_injectors
Super DSMtalker
97 GSX
y_injectors's Gallery
Feedback Score: 5 reviews
My 2g AWD is in need of shift solenoids. I have a 1g awd trans in my garage. Are the shift solenoids or valvebodies interchangeable? I know the 2g has a W4a33ev-s. not sure on the 1g trans but it came off a 92.
y_injectors is offline   Reply With Quote
Old 02-10-2011, 11:27 PM   #2
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
Re: Replacement shift solenoids
The valve bodies are physically interchangeable but they are tuned different. The solenoids MAY be interchangeable depending on the year of the 1g transmission, the wrong year will trash your tcu.
While it's true beauty is only skin deep, UGLY goes clear to the bone... BISHILVR
Old 02-10-2011, 11:38 PM   #3
y_injectors
Super DSMtalker
97 GSX
well that 92 awd had a 3 plug tcu if it helps
Old 02-10-2011, 11:41 PM   #4
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
It should be ok then.
Old 02-11-2011, 03:54 PM   #5
GDNF2ET
Super DSMtalker
GDNF2ET's Avatar
93 talon AT/awd
GDNF2ET's Gallery
Feedback Score: 1 reviews
The three plug TCU ( 91 to early 92) is the older of the 1g harnesses...Neither 1g harness ( early or late) has the lockup solenoid that your 2g needs either..
93 talon, AWD, AT, 35R, eprom tcu, 950 inj., 264/264 cams, 255 pump, SBR front mount, Hawver intake, SMC Meth kit, Hughes converter, Shep 4 spider upgrade
GDNF2ET is offline   Reply With Quote
Old 02-11-2011, 04:20 PM   #6
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
A 1g non turbo will have the lockup converter though. And as far as years go, the very early ones are the ones to stay away from 90-91 they had the low resistance solenoids.
Old 02-11-2011, 05:29 PM   #7
GDNF2ET
Super DSMtalker
GDNF2ET's Avatar
93 talon AT/awd
GDNF2ET's Gallery
Long story short, that early 1g awd trans you have will not help you source solenoids for your 2g...
Old 02-11-2011, 06:26 PM   #8
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Best bet is to go to a junkyard and pull the solenoids from a n/t 1.8 or 2.0 from late 92-94.
Old 12-01-2011, 09:47 AM   #9
Joe Schafer
Plymouth/Laser/1990
Joe Schafer's Gallery
Your car is going to either have a all 3 ohm solenoids or a mixture of 3 ohm and a 13 ohm solenoid. If a 3 ohm solenoid is used where a 13 ohm solenoid is used, your computer will be fried. I don' t know if the reverse is true. When you replace your solenoids, test each solenoid with a ohm meter and make sure the new ones your are replacing are the same resistance value. The 13 ohm solenoid started being used in 93, so that should be the cut over for cross reference purposes. More info can be found at these links:
http://www.teckpak.com/spgm.cfm?id=MSKM-17593
http://www.teckpak.com/spgm.cfm?id=MSKM175
Joe Schafer is offline   Reply With Quote
Old 12-01-2011, 01:20 PM   #10
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
The reverse is not true, you can go one way but not the other.
