Egine idles at like, 50 rpm and CEL is on. - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Closed Thread
Old 06-15-2011, 09:26 PM   #1
MissSpyderGST
Super DSMtalker
MissSpyderGST's Avatar
97 Spyder GS-T
MissSpyderGST's Gallery
Feedback Score: 1 reviews
I just got out from work, and went to crank it up. It started up just fine then immidiatly went down to approx 50 rpm, and was shaking very violently. Eventually, the CEL came on. I went home, looked in my repair book, and it started with spark plugs and wires, and even an air cleaner (my 14b has busted oil seals, so I thought that my air filter was clogged, due to the oil deposits). Spark plugs had a white ash on the arch, and my filter had debris. Bf, hooked up the diagnostic tool and it was stating the codes 0P100 and 0P300, which means MAF sensor and Cylinder Misfire. When the new parts were in, the car cranked up fine and was driving just fine for 2 minutes, and in the middle of driving, started back up. So, once Brandon gets off from work, we will be working on it together. We think it's the MAF, and other possibilities are, coil pack, EGR valve, catalitic convertor and rarely fuel injectors.
My question is, has anyone ever had this problem as well? And if you have, what would be your next step? Did your car ever backfire (mine did occasionally, and wasn't a very dramatic backfire)?
Thanks!
DSMs for LIFE!
-Sara (Say-ruh) :p
MissSpyderGST is offline
Old 06-16-2011, 11:35 AM   #2
Mischif
Super DSMtalker
93 Eclipse 1.8T
Mischif's Gallery
Re: Egine idles at like, 50 rpm and CEL is on.
idling at 50 rpm sounds like it's only running on 1 cylinder, maybe 2. When its doing it, check and see if all cylinders are getting spark, then check for fuel and see if you can feel the injectors pulsing.
Mischif is offline
Old 06-16-2011, 12:54 PM   #3
MissSpyderGST
Super DSMtalker
97 Spyder GS-T
But with the CEL on, it's stating MAS error. So I'm wondering if it needs to be cleaned or if it needs to be replaced... I'm about to go back to the parking lot and check on it. I knew it was time for a tuneup, which is why I replaced all spark plugs and wires. Considering my car was backfiring as well, is beyond me. :/
DSMs for LIFE!
-Sara (Say-ruh) :p
Old 06-16-2011, 01:21 PM   #4
Jmonet1620
Hardcore DSMtalker
Jmonet1620's Avatar
AWD 2G
Jmonet1620's Gallery
Feedback Score: 6 reviews
Check to make sure the MAF is plugged in all the way. My MAF plug is semibroken and sometimes it comes off enough that is doesnt make a good connection. When that happens it runs similar to what you described.
EVO316G@29psi + E-85 = sex on the streets
Originally Posted by DSM Loki View Post
Holy christ if you don't follow rule #7 before you post again I will stab everything you've ever cherished. Twice.
Jmonet1620 is offline
Old 06-16-2011, 01:40 PM   #5
lost spyder
Super DSMtalker
lost spyder's Avatar
Evo VIII
lost spyder's Gallery
Feedback Score: 9 reviews
Check that crank sensor as well, a buddy of mine was only running on two cylinders and very low rpm when his 7 bolt walked. Could even have been skipped timing on shutdown.
I've had it happen first hand. Drove to work 40miles, shut it off. Got out of work and wouldn't fire just backfired and popped. Checked everything but timing and it was nearing 1am so came back next day and tore it apart in the middle of a blizzard to find it jumped 6 teeth.
Put a new belt and tensioner on and drove on my merry way home. I recently took that head off that motor when i parted the car out and saw the ever slightest nicks in my piston tops. But i got away with murder.
Daily Grind: 2g gsx, rev. 7 bolt, manley ibeam/wiseco combo, o-ringed, mls, l19, supertech val/spr/ret, hx35r ect.
Garage whore: Built 2.1 destroker evoVIII with forward facing hta3586. Hasn't seen daylight in almost 2 years. Litterally, i haven't even seen it in nearly a year.(Back at my parents house in nj under wraps.)
lost spyder is offline
Old 06-16-2011, 04:03 PM   #6
MissSpyderGST
Super DSMtalker
97 Spyder GS-T
Yeah, I just got back from looking at it at the Super Wal Mart parking lot (sighs), and it shot me the P0300 code, which I'm sure everyone is familiar with multiple misfire. The list that this code gave me are:
-faulty spark plugs/wires
-faulty coil pack
-faulty 02 sensor
-fuel injectors
-burned exhaust valve
-catalytic converter
-stuck/blocked egr valve/passages
-camshaft position sensor
-defective computer
I replaced the plugs with the usual NGKs, and BOSCH wires (best Autozone had), the 02 sensor is fairly new, as well as the camshaft position sensor. If the catalytic convertor was going bad, it would smell like rotten eggs, from my understaning.
In my repair manual, it says:
-Vacuum leak (possibility of a boost leak?)
-leaking egr valve
-spark plug and wires
-air filter clogged (which I replaced)
-fuel pump not delivering sufficient fuel to injection system
-leaking head gasket
-timing belt and/or pulleys worn
-camshaft lobes worn
What can I eliminate (besides the parts I replaced)? And, if it were my coil pack, would the car not even crank, anyway? Very odd, and I have been researching all day long about this.
If it was your timing belt (which I know it's getting about that time for mine to be replaced), would your pulleys have gone bad as well?
DSMs for LIFE!
-Sara (Say-ruh) :p
Old 06-16-2011, 05:19 PM   #7
90BLACKAWDTSI
Super DSMtalker
90BLACKAWDTSI's Avatar
2006 Evo IX
90BLACKAWDTSI's Gallery
Sounds like the dreaded sign of a failing hydraulic tensioner and the belt has slipped and you are out of time.
90BLACKAWDTSI is offline
Old 06-16-2011, 05:28 PM   #8
MissSpyderGST
Super DSMtalker
97 Spyder GS-T
Yeah, I've been narrowing it down with all my research, and it leads to timing.
Btw, nice "catchphrase."
At least the belt is the next cheapest thing on my list haha.
DSMs for LIFE!
-Sara (Say-ruh) :p
Old 06-16-2011, 05:33 PM   #9
90BLACKAWDTSI
Super DSMtalker
2006 Evo IX
Well at least you seem to be on the right track and headed in the right direction
Old 06-16-2011, 05:35 PM   #10
MissSpyderGST
Super DSMtalker
97 Spyder GS-T
I try. To be honest, I was like, going insane without my car and started freaking out, locked my keys in there and locked the Suzuki keys, in there and had to get Brandon to pick me up and calm me down haha... I've had so many problems with this car, that it's gotten to where I laugh when something wrong goes on.
DSMs for LIFE!
-Sara (Say-ruh) :p
Old 06-16-2011, 07:46 PM   #11
ET93
Super DSMtalker
ET93's Avatar
92 Eagle Talon TSI AWD
ET93's Gallery
Feedback Score: 3 reviews
If I were you I would order some NGK wires or equivalent and take those Bosch wires back when they get there. I had those things on my car for about 5 min before I went to remove them and 2 of the wires held onto the spark plug pulling the metal all the way to the end of the boot making the boot not sit all the way down and hover about the valve cover.
But anyways backfireing is common to bad timing and you can roughly check your timing by pulling the top cover and lining up the harmonic balancer to the TDC on the bottom valve cover then matching the teeth on the cams.
ET93 is offline
Old 06-17-2011, 10:57 AM   #12
lost spyder
Super DSMtalker
Evo VIII
I think you got a bad set or something. Did you use dielectric grease? On my old spyder my magnecore's took a shit and I used these from the local autozone. Not only did they make the best engagement to the plug head i've ever seen on our cars but the boots fit perfect and they never gave me any issues for the time i had the car ~4years. Running around on a 60-1 daily at 28psi. God that thing was laggy .
Old 06-17-2011, 01:06 PM   #13
MissSpyderGST
Super DSMtalker
97 Spyder GS-T
Lol, all I use is BOSCH. You must have gotten a bad set... But I think I discovered my problem, thanks to my bf. I'm waiting on my ignition coil pack to come in. Reason why we think this is it: The plug wires don't "pop" into place on the coil pack itself. SO I can barely touch the wire and it comes out. It's coming in later today, so I will keep you guys posted. Note: My first time EVER replacing the coil on this car. It's much different from my Mercedes lol.
DSMs for LIFE!
-Sara (Say-ruh) :p
Old 06-19-2011, 11:02 AM   #14
beachboostin
Eagle Talon TSi '92
beachboostin's Gallery
This may also be from left field, but have you tried to make sure all the intercooler piping is good and tight. A buddy of mine had a 2g gst with the smic and greddy up pipe and that thing came off regularly and his car ran like ass, if at all, because of it. Just another thing to check.
beachboostin is offline
Old 06-19-2011, 02:51 PM   #15
lost spyder
Super DSMtalker
Evo VIII
dsm/4g63 plug wires don't "snap" into the coil pack. They just chill in the tubes, all that really keeps them in place is the boot that slides over.
And i hope you know i was agreeing with you, my post was in refference to what et93 said. BOSCH wires for a daily driven dsm are the shit.
Closed Thread
