Bigger Injectors ?? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 01-04-2013, 03:38 PM   #1
wing3r09
wing3r09's Avatar
99 Eclipse, GST
wing3r09's Gallery
Bigger Injectors ??
Hope this is in the right forum, and hasn't already been answered.
I have been noticing when I am driving, that when pulling in 2nd at about 6000 rpm i start to notice almost like a hesitation in my car. I'll then shift to 3rd pull again to high RPM and again, it'll seem to be stuttering.
I feel like it could be fuel cut out possibly, where maybe im getting more air than fuel causing a bad burn. If thats the case would bigger injectors be the solution? If so how big should I go? Do i need a bigger fuel pump? Would i need a 3 bar map sensor?
Thank you guys for your time!
wing3r09 is offline   Reply With Quote
Old 01-04-2013, 03:41 PM   #2
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
Re: Bigger Injectors ??
If the car is stock or nearly stock then factory injectors are fine. Putting in bigger injectors requires tuning as the ecu does not know that the injectors are larger.
Fuel cut is a very harsh stop, stuttering at high rpm generally is caused by igniton issues. Bad plugs/wires, possibly bad grounds or coil packs.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 01-04-2013, 04:14 PM   #3
wing3r09
wing3r09's Avatar
99 Eclipse, GST
wing3r09's Gallery
It is nearly stock, i haven't done much to it, FMIC, Hard piping, BOV, Tubular Ex Header, Full 3in Exhaust.
The wires/plugs were replaced not to long ago, could be the coil packs though. Is there a way i can check them, or just have to buy new ones?
Old 01-04-2013, 04:21 PM   #4
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
What type of plugs and wires did you use and what gap? You can check the packs for corrosion by looking inside the towers. They can get heat cracks and the way that I test for that is to start the car at night, or a dark garage and use a spray bottle to wet the coil packs down a bit and look for arcing.
99 Spyder "GSX"
Sean Clancy
Old 01-04-2013, 05:42 PM   #5
MindBlowin03
Honorary Moderator
MindBlowin03's Avatar
'97 TSi AWD
MindBlowin03's Gallery
Feedback Score: 20 reviews
Have you done a boost leak test? How about a datalog to check for knock?
-Nick
'97 Talon AWD - 6 bolt / 8.5:1 Mahle/Eagle combo / T3 HX-40(.70 A/R) / ported/polished head / ACT 2900 / 4 puck unsprung / HKS 272s / Cyclone Intake / Dual 255's(intank/inline) / FIC 1150s / Spoolin' Up AFPR(45psi) / -6an fuel lines / Meth/water(50/50) / DSMlink V3 (SD) -- 565 awhp 524 lb/ft
My build thread
'98 Spyder GS-T - 6 bolt block / EVO 9 injectors / EVO 9 Fuel pump / EVO3 16g / 3" turbo back exhaust / ACT 2100 / DSMlink V3 (SD)
MindBlowin03 is offline   Reply With Quote
Old 01-05-2013, 02:11 PM   #6
wing3r09
wing3r09's Avatar
99 Eclipse, GST
wing3r09's Gallery
Sean485 i believe they're both NGK, also i did not do replace them the previous owner did not long before i purchased it, so i do not know the gap :/
MindBlowin03 I have not done either of those. I have a Boost leak tester, just have not done one yet.
Old 01-05-2013, 02:48 PM   #7
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Check plugs for thier color, condition and gap and do a BLT then come back. There is no point in us giving you possible problems if they are not physically verified before saying 'nah cant be it cause so and so did this or that'.
99 Spyder "GSX"
Sean Clancy
Old 01-21-2013, 10:58 PM   #8
nettslash
Hardcore DSMtalker
nettslash's Avatar
91 TSi awd
nettslash's Gallery
Check your resistance at the coil pack. I am sure you can find a guide by searching, or using a Haynes/Chiltons manual. If you don't know when your plus/wires have been changed, its not a bad idea to change them out. Also check to see if your coil pack is arcing. I had a small chunk somehow missing from mine that I didn't see until after I pulled the pack itself. I also had VERY similar symptoms, as to what you are experiencing, and this was the problem.
I have a place in my heart for turbo civics.
nettslash is offline   Reply With Quote
Old 01-22-2013, 10:12 AM   #9
NEWTODSM97GST
mitshubishi/GST/1997
NEWTODSM97GST's Gallery
check your o2 sensor aswell.
NEWTODSM97GST is offline   Reply With Quote
Old 01-23-2013, 08:59 AM   #10
SLEEPS
Ultra DSMtalker
SLEEPS's Avatar
93 D21 beater
SLEEPS's Gallery
Feedback Score: 3 reviews
^ For what... what should he be checking the O2 sensor for exactly?
2015 Sorento GDi. 1993 D21 beater.
Originally Posted by LandoAWD View Post
Forum users are generally idiots.
SLEEPS is offline   Reply With Quote
Old 02-11-2013, 01:59 PM   #11
dskolevo
dskolevo's Avatar
12' Lancer EVO
dskolevo's Gallery
I had an issue kinda like this, only stuttered after about 5k under boost, with no boost ran fine. Check for boost leak once, its a long shot but i bought all new ignition stuff and still was have bad shuttering found a bad leak on one of the couplers now she runs fine.
dskolevo is offline   Reply With Quote
Old 02-16-2014, 11:28 PM   #12
mitech87
90 talon,evo,wrx,leg gt
mitech87's Gallery
check for boost leaks
mitech87 is offline   Reply With Quote
