Re: Trunk/Spolier Advice
That will work fine, even as a permanent solution, but is a lot more work than just welding them shut and smoothing it out. If i were to do it that way.I would fiberglass the bottom, then put somthing in the hole to fill the void. Then put glass on top. Something like a thin peice of metal cut with the same circumference as the hole(maybe a dime,penny?). That way there would be no void in between the two peices of fiberglass.
HELP= What we all need. Actually, it is the featurein MS that assists in generating more questions. When the help feature is used correctly, users are able to navigate through a series of Help screens and end up where they started from without learning anything... but now it's their fault and they should buy more RAM.
Originally Posted by BISHILVR
Are you kidding me? the Dsm is the most reliable bullet proof tuner car that was ever produced..
