Excessive Window Condensation - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Body Tech and Appearance
Old 01-13-2013, 03:23 PM   #1
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Question Excessive Window Condensation
Winter in Canada, will probably stay between -10c and -30c for the next few months. My problem is I have alot of condensation/ice build up on the door windows. My heater works good and blows hot air but even after 2 straight hours of driving with the defrost on full the windshield and door windows are still coated with ice. The windshield ice is just by the rear-view mirror but most of my door windows are so fogged up/icy that I need to lean forward to look out them. Does anyone have a fix for this or an idea why it may be?
djinc is offline   Reply With Quote
Old 01-13-2013, 03:31 PM   #2
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
Re: Excessive Window Condensation
What is the condition of your door and window seals? Can you wobble the window in its track at all?
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 01-13-2013, 04:37 PM   #3
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Both windows are solid, although the driverside seems like it used to sit on more weatherstripping. You can push on the stripping and expose the interior to the cold. Here are some pictures aswell. Sorry, crappy phone.
Old 01-13-2013, 05:31 PM   #4
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Just went for a quick drive, this is what I'm dealing with:
Old 01-13-2013, 05:33 PM   #5
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Your images don't work.
99 Spyder "GSX"
Sean Clancy
Old 01-13-2013, 07:34 PM   #6
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Can you see these?
Old 01-14-2013, 10:32 AM   #7
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
This is only the drivers side ofcourse, the passenger side is in much better condition but the same concern still applies.
Old 01-14-2013, 03:33 PM   #8
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Your outer window seal is obviously damaged and is likely letting moisture accumulate inside of your door and hence interior causing the icing inside. It's hard to tell if the window is positioned properly or not as I havent looked at a hardtop 2g closely in quite some time.
99 Spyder "GSX"
Sean Clancy
Old 01-14-2013, 03:57 PM   #9
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
It looks to me as though that window is tilted forward. Try adjusting your glass, regulator, rails, etc.
10HR OPR BSMR
DSM Loki is offline   Reply With Quote
Old 01-15-2013, 07:33 PM   #10
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
When you have your defrosters on, for full effect you have to have your a/c compressor on and working to pull the moisture out of the interior. If your carpet or floormats are wet or damp you will never get clean windows, also remember to have your hvac settings to "outside" or "fresh air" not "recirculate" on recirculate you are taking moisture from inside the car, including your breath and just cycling it over and over without ever removing the moisture. If it comes down to it, you can use big desicant packs inside your car to try to dry it out.
Old 01-17-2013, 09:33 AM   #11
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
I am looking for that outer seal, wherever I search most people are looking for the inner weather stripping. Does anyone have a part number for the outer?
Yes the glass is forward, if you check my 3rd picture that plastic/rubber is broken so it eventually just leans forward again.
So I have had it on recirculate forever thinking it would recirc the warm air and dry it out. I switched it and it seems to be alot better. Also, what is that small roller beside the center console vents that has a blue pic on top and white on bottom?
Thanks for everyones help so far!
Old 01-18-2013, 02:24 PM   #12
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Those are just to close off the vents that you arent using.
Old 01-18-2013, 05:53 PM   #13
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Not the one on the left side, that's pretty self explanatory, I am wondering what the one on the right side does.
Old 01-18-2013, 06:06 PM   #14
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Those close off the vent, or partially close it if you or a passenger want a different amount of air blowing from a certain vent, they all have their own.
Old 01-18-2013, 06:33 PM   #15
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Wow, a 2g dsm with manual windows? Don't see that very often...
99 Spyder "GSX"
Sean Clancy
