Crankshaft Pulley Problem(s)! - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Old 01-21-2013, 10:07 PM   #1
RallyEclipse98
DSMtalker
RallyEclipse98's Avatar
Eclipse
RallyEclipse98's Gallery
Feedback Score: 2 reviews
I am trying to get off my crankshaft pulley for timing/water pump/head gasket change and I'm confused. It appears that when I do finally get the pulley off the engine, it will slam into the body of the car. I cannot just yank the thing out through the wheel well, it looks like it will hit the inside of the engine bay.
There is about 2 inches between the pulley and the body. Is this okay or do I have to drop the engine more? Right now the front motor mount is loose and the passenger motor mount is completely off. I tried pushing down on the motor and it won't hunker down enough.
I read on 2gnt that I would have to take out a body mount or something?
Any help would be appreciated. This seemed a lot easier in the write-ups.
RallyEclipse98 is offline   Reply With Quote
Old 01-22-2013, 12:14 PM   #2
RallyEclipse98
DSMtalker
Eclipse
Re: Crankshaft Pulley Problem(s)!
On 2gnt.com someone said I have to remove the front crossmember. It seems like that would be the only way to lower the engine enough.
Old 01-24-2013, 08:28 AM   #3
TylerLorenz
90 Eagle Talon TSi AWD
TylerLorenz's Gallery
I never ran into this issue before. Have any way to send us pictures?
TylerLorenz is offline   Reply With Quote
Old 01-27-2013, 06:38 PM   #4
RallyEclipse98
DSMtalker
Eclipse
Problem solved!
Earlier in the project I took out the front motor mount bolt and later put it back in (in an attempt to jack the engine up higher). I accidentally put the bolt through one of the holes in the bushing so therefore the engine mount was holding up the engine above the intended bolt hole. The engine couldn't sit low enough. So I just took the bolt out completely and got the engine to sit on the front crossmember. Everything works well now.
Old 01-28-2013, 06:03 PM   #5
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
Thanks for updating your thread, all too often threads go on forever into cyberspace without resolve and that in turn causes future users to create new threads about the same problems.
BISHILVR is online now   Reply With Quote
