Ruff Cold Start? (Solved) - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Electronics Tech
Old 01-31-2013, 08:43 PM   #1
cars4life13
97 Eclipse GSX
cars4life13's Gallery
Thumbs up Ruff Cold Start? (Solved)
Hey guys, after a good amount of searching the forums i wanted to share on how i solved the cold start issue on my 97 Eclipse GSX. I decided to make this thread for anyone having the same issue and wants the right answer on how to fix this issue.
Symptoms: Extremely Ruff Cold Start
My car would crank, crank, crank and Crank. After about 10 mintures of cranking and killing the battery she would slowly Start.
Conclusion: Replace the Coolant Temperature Sensor
AUTOZONE PART # SU4293
LINK
http://www.autozone.com/autozone/par...29394_0_18589_
LOCATION: On the Back side of the Thermostat Housing with 1 connector on it.
Replace the Sensor and your Golden
My car now starts perfect regardless of the temperature.
cars4life13 is offline   Reply With Quote
Old 01-31-2013, 08:55 PM   #2
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Re: Ruff Cold Start? (Solved)
I have replaced both coolant temp sensors and my thermostat and I still have a rough cold start as you described, but mine is only like that in the summer, in the winter it runs perfectly. Any ideas on that?
djinc is offline   Reply With Quote
Old 01-31-2013, 09:26 PM   #3
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
That's fine and well, but you could have checked the temp sensor with an ohm meter rather than just guessing it was the problem.
Djinc - First thing to check is basic health of the engine. Fuel pressure, compression, boost leaks, sensor connections, etc. If you don't have a check engine light and the other stuff checks out then you can check other things. I however NEVER recomend throwing parts at a car.
99 Spyder "GSX"
Sean Clancy
Sean485 is online now   Reply With Quote
Old 01-31-2013, 09:53 PM   #4
cars4life13
97 Eclipse GSX
Probably should get a Ohm meter but i just did my research and replaced the part.. Its only $17.00.
Old 01-31-2013, 10:02 PM   #5
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
I will do a compression test on Saturday, my sensor connections are good and no MILs are on. Ill see if I can do a smoke test for leaks, I know I have oil leaks and the oil pressure is low but I can't afford to fix these at the moment.
Old 02-02-2013, 11:23 PM   #6
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
Thanks for posting the fix! this is what we could use more of on here.
Old 02-03-2013, 11:56 AM   #7
cars4life13
97 Eclipse GSX
Thanks Bud
Old 02-03-2013, 01:50 PM   #8
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Okay so I just finished the compression test and I got:
#1 - 120
#2 - 105
#3 - 115
#4 - 105
I also noticed a crack in my valve cover while doing this, do you guys think it would be okay to clean it up and seal it with jb weld or am I better off just buying a new one?
Old 02-03-2013, 02:07 PM   #9
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
If you can get the valve cover very, very clean and let the jb weld set it will seal fine.
As for the compression that is VERY low for a 2g, borderline surprised it starts TBH. I would check the mechanical cam/crank timing to be sure it hasn't jumped time.
99 Spyder "GSX"
Sean Clancy
Old 02-04-2013, 04:03 PM   #10
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Are you sure that your doing the compression test properly? and are you sure that the tester is a good one?
Old 02-04-2013, 04:06 PM   #11
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
The tester is good. I took out all the plugs, and let it crank for about 4 seconds on each cylinder with the gas pedal to the floor.
Old 02-04-2013, 05:17 PM   #12
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Always let it crank until the gauge quits moving, your reading is the highest that the gauge will go.
Old 02-04-2013, 06:11 PM   #13
djinc
djinc's Avatar
97 Talon TSi AWD
djinc's Gallery
Well I did the test twice because I forgot to push the gas first time so I am fairly sure I did it right and long enough. However I forgot to mention, when I did cyl 1 my girlfriend said little white chips flew out of cyl 2, I am sure this is a bad thing but what does it mean? Also how much compression should a stock 2g have?
Old 02-04-2013, 06:43 PM   #14
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Compression should be 140-160 or so in a really good engine, they will run with much lower than that but it gives you an idea of the overall condition. White chips could be anything, (especially to a girl) it might have been white carbon or just filth that was laying outside of your spark plug holes.
Old 02-04-2013, 06:57 PM   #15
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Check the timing... If the timing is correct then you can start to look deeper but if the timing has jumped, and you keep driving it it will jump again and mash valves.
99 Spyder "GSX"
Sean Clancy
