1G hunts at idle - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
» Wheel & Tire Center
Old 02-21-2013, 10:38 AM   #1
Octane
DSMtalker
Octane's Avatar
98 Talon Tsi Awd
Octane's Gallery
1G hunts at idle
I am having a hell of a time getting this thing goin. When I bought it the lady said it wouldnt start. So I tested and replaced the ISC and the ecu since the caps were corroded. I then discovered the idle switch connector was broken and I replaced it and set it to contact the butterfly. Now I got the thing running but it hunts at idle worse when its cold. Once I put it into gear (reverse or drive) the car idles like it should at 1000. It kind of bogs out at higher rpms too. The car is a 93 plymouth laser turbo AWD automatic
Octane is offline   Reply With Quote
Old 02-22-2013, 07:17 AM   #2
SLEEPS
Ultra DSMtalker
SLEEPS's Avatar
2013 Sorento LX GDi
SLEEPS's Gallery
Feedback Score: 2 reviews
Re: 1G hunts at idle
Does the idle smooth out or stay somewhat steady once the car warms up?
"If i'd done it for the money I'd been a F**** lawyer" -mackelmore
"Swerving in and out of this fight I'm in, I was born to be a curious blend"-sintax.the.terrific(lawyer/rapper)
Originally Posted by LandoAWD View Post
Forum users are generally idiots.
SLEEPS is offline   Reply With Quote
Old 02-22-2013, 10:32 AM   #3
Shayne_ZTS
DSMtalker
Shayne_ZTS's Avatar
1993 Mitsu Eclipse GSX
Shayne_ZTS's Gallery
Feedback Score: 1 reviews
Iirc automatics don't idle that high in gear. I could be wrong since I haven't seen an auto in a while. Have you done a boost leak test?
Shayne
-1993 Mitsubishi Eclipse GSX-
Shayne_ZTS is offline   Reply With Quote
Old 02-23-2013, 04:53 PM   #4
Octane
DSMtalker
Octane's Avatar
98 Talon Tsi Awd
Octane's Gallery
Wink Re: 1G hunts at idle
Okay ive been tinkering with it today. First of all I had a very hard time getting it started. It took a lot of cranking and dieing out to get it going. It fired up and revved to 3000 and came down too 1200 and hunted to 1500 repeatedly. So I started spraying brake clean on the intake manifold and no change in RPM.
Then I unplugged the booster line from the manifold and it had some pretty good suction. When in gear it idles normal but it sputters very bad and has almost no throttle response. One thing I did notice is that the idle bumps up when I turn on the blower motor.
Old 02-23-2013, 05:38 PM   #5
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
Feedback Score: 4 reviews
First thing to do is to make a boost leak tester and check the system for intake air leaks with it. Second thing that I would do just for good measure is replace the coolant temp sensor, if its original its very likely not very accurate anymore and its a cheap part to replace.
Old 02-23-2013, 06:08 PM   #6
genegoesfast
1999 GSX
genegoesfast's Gallery
Have you checked the coils of the isc to make sure hey read 29-34ohms? Also check your biss screw and your throttle switch.
genegoesfast is offline   Reply With Quote
Old 02-23-2013, 09:57 PM   #7
BISHILVR
BISHILVR's Avatar
MITSUBISHI GST 1999
BISHILVR's Gallery
That right there is sage advice!
Old 02-24-2013, 02:07 AM   #8
Octane
DSMtalker
Octane's Avatar
98 Talon Tsi Awd
Octane's Gallery
Yes sir I replaced my ISC with one within spec. I also replaced the idle switch because the connector was broken off inside. The biss screw I have tried to play with and it hasnt moved the idle up or down.
