Hey whatsup, well I finally got the time this morning to remove the stock fog lights. It went pretty smooth, just took away to get the bolts off.
Well I bought a pair of new 3A hyperwhite fogs. They are pretty small and they are very bright, They have two lights in both of them. A white and blue. So i take them out of the box and there are 3 wires hanging out. A black, a white, and a blue. I figuring the black is the ground and white is power, but the blue wire is that a power wire too? It goes to the blue light. I want to use the already existing wiring that my old set used. But they used only two wires, a red and a black. Could I splice the blue wire into the white wire? Then cut the old connecter switch off the stock fogs and then wire the white wire with the blue spliced in and black wire to that old fog connector switch? Then just plug them back in to the old wiring female switch? Also would this create too much voltage and short things out because now the power wire is used to light two different lights. Any input would be cool
I know this is a little bit confusing, if you need futher explanatin tell me.
Thanks
-Matt- 20G, FMIC, Full 3inch, 550s, and supporting mods
2007 Mazdaspeed 6 Black- Turbo, AWD, Direct Injection, 6 Speed
2006 Mazda 6i Glacier Silver- (Given to Fiance)
