fire wall - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Audio Tech
Notices
Old 12-11-2000, 06:52 PM   #1
NightriderAWD
NightriderAWD's Gallery
i am going to run a power cable to an amp for a 12in mtx blue thunder sub that i want to put in my "trunk", so my question is: where is the easiest place to drill through the fire wall so that i can run the wire to the inside. Or is there some other way i should run the wires?
NightriderAWD is offline   Reply With Quote
Old 12-11-2000, 11:03 PM   #2
91TalonAWD
Honorary Moderator
1991 Talon TSi AWD
91TalonAWD's Gallery
Question
It depends on what guage wire you are going to run (8 ga.,4ga.,2ga.,etc), you only need one, power. Do you have a 1g or 2g?
1991 Black Talon AWD
1992 White Eclipse GSX
1991 Red Talon Turbo FWD
In Loving Memory of Brian Carpenter, only the good die young, dead at 21 by 2 people street racing who ran a red light, if you're going to street race, race safe.
91TalonAWD is offline   Reply With Quote
Old 12-12-2000, 04:24 PM   #3
sab4you
Hardcore DSMtalker
1998 Honda Accord Coupe
sab4you's Gallery
I ran my wire on the passenger side, there is a pritty big rubber grommet already there, all I had to do was smush the power wire into it along with the cars stock wiring, then run it to the trunk. Alot easier than drilling a new hole, and end up drilling into the ECU or something
sab4you is offline   Reply With Quote
Old 12-13-2000, 04:32 PM   #4
90GSTforME
DSMtalker
90GSTforME's Gallery
i tried using that grommet for existing wires for mine but i couldnt fit two 8 guage lines through.
I drilled a hole in the firewall on the passenger side a little to the drivers side of the battery and way down.
It worked pretty well.
by the way this is in a 1G, not sure about 2G's.
90GSTforME is offline   Reply With Quote
Old 12-13-2000, 07:48 PM   #5
mark93
Super DSMtalker
tahoe
mark93's Gallery
Feedback Score: 1 reviews
On the 1g if you look right below the brake booster you will see a greyish grommet when i think the speedometer cable goes thruogh if you dont want to drill holes you can pop out the grommet and put all neccesary wiring through it. So far i have 2-4guage 1-10guage no problem!
mark93 is offline   Reply With Quote
Old 12-13-2000, 09:50 PM   #6
NightriderAWD
yup, its a 1G. So does the gromet behind the brake have just a wire running through it, or something bigger?
also, i read somewhere that running the power wire with the remote wire could cause some interference, or was it with the rca cables...
anyway, thanks for the help
Old 12-13-2000, 10:02 PM   #7
mark93
Super DSMtalker
tahoe
mark93's Gallery
No, it is just the speedo? cable(someone correct me if i am wrong) .
Do not run your rca cord with your power wire. The rca will pick up noise(the infamous altenator whine) always run your speaker and rca along the opposite side of the car.
Old 12-13-2000, 10:19 PM   #8
NightriderAWD
thanks for the quick responce,
so is the spedo cable right behind the brake boot?
Old 12-13-2000, 10:29 PM   #9
mark93
Super DSMtalker
tahoe
mark93's Gallery
Talking
It is off to the left and about 6 in down. Look for a grey grommet with a cable from the tranny going through it. I looked at my 93 and 91 and they both have the grey grommet. It is about 1.5 in. in diameter. If you look from inside the car the cable goes through the firewall and to the dash. If you look in the faq they might even have a pic to help you out that is where i found out about it from..
Good Luck!
Old 12-23-2000, 10:05 AM   #10
MoBoost
Ultra DSMtalker
1990 Eagle Talon
MoBoost's Gallery
IMHO it is much easier to use the stearing colon boot - just poke the rubber with a knife.
I have quite I few things running thru that hole too :
Amp - 10GA
FuelPump - 8GA
Boost gauge - 1/4"
Ammeter - 2x10GA
Oil Pressure - 1/8"
Water Temp - 1/4"
EGT - 1/8"
Alarm Speaker - 1/8"
697whp/E85/Stock ECU
www.abelracing.com
MoBoost is offline   Reply With Quote
Old 12-31-2000, 06:22 PM   #11
JC 97 GS-T
DSMtalker
JC 97 GS-T's Gallery
Thumbs up
I have a 2g and the easiest place i found was under the battery. I had to run 4 guage so I didn't have many options.
JC 97 GS-T is offline   Reply With Quote
Old 01-01-2001, 12:30 PM   #12
NightriderAWD
Ya, i'm running the wire through the steering coloumn grommet
