HELP! How do you relocate battery to trunk? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Audio Tech
Notices
Old 03-30-2002, 09:21 PM   #1
wc_one
Super DSMtalker
A
wc_one's Gallery
Where can I buy a relocation kit and how do I install it (where do I route the cable?)?
wc_one is offline   Reply With Quote
Old 03-31-2002, 01:14 AM   #2
Turbo2
Ultra DSMtalker
1991 Matsuda Roadster
Turbo2's Gallery
Summit Racing has them. It would come with instructions, just make sure you have a long vent tube for the battery. Wouldn't be good to have your tailpipe or a rear suspension piece fall off
Andrew
1991 Mazda Miata aka Mazda Roadster - 98ci of fury
Turbo2 is offline   Reply With Quote
Old 03-31-2002, 09:42 AM   #3
Rodman
1998 Jetta GL
Rodman's Gallery
I beleive 'Taboo' did this at half the price with great results, shoot him an email.
Rodman is offline   Reply With Quote
Old 03-31-2002, 02:57 PM   #4
klipzracer
DSMtalker
1991 TSI
klipzracer's Gallery
i just did this last week on my GSX. i bought the relocation kit from summit racing that's 40 bucks. mount the battery on the opposite side of the fuel pump that way its opposite of the engine and the wieght is more equally balanced.
1991 Tsi Fwd auto.....5-speed swapped, converted non-turbo 4g63 to turbo!
klipzracer is offline   Reply With Quote
Old 03-31-2002, 06:21 PM   #5
wc_one
Super DSMtalker
A
wc_one's Gallery
Where did you route the cable through?
Old 04-01-2002, 08:36 AM   #6
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
GST97ORL's Gallery
I've done this as well. I routed the cable down past the motor mount (be careful to secure it away from the mount so it doesn't rub the cable) and then attached it under the car and ran it back to the trunk. Once it's at the rear, route it up thru one of the grommet/seals on the trunk bottom and resecure the grommet (after cutting it appropriately) and then connect your battery's positive terminal. For the negative, just ground the original negative cable to a place in the engine bay. Ground your battery's negative terminal in the trunk. This way you're not running two cables to the trunk.
I got my box and relocation kit from Summit for a total of something like $40.
If you need pics, let me know.
Bye bye 2g, hello 1g! Can I change my name to 91TSiORL??
GST97ORL is offline   Reply With Quote
Old 04-01-2002, 11:51 AM   #7
wc_one
Super DSMtalker
A
wc_one's Gallery
Cool, thanks for the info. I noticed from Summit's site that the battery box is kinda big, much larger than the battery itself. Where in the trunk did you strap it down to?
Old 04-02-2002, 09:54 AM   #8
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
GST97ORL's Gallery
Yeah, you're right, it is much bigger than the battery. I just stuffed an old towel in there with it to hold it steady in the box. As far as where it is, it's secured to the trunk floor with screws. Here's a pic, it's actually two halves made into one, it's not the best but here goes...
Old 04-05-2002, 12:12 AM   #9
Birdman90
Mitsubishi/Eclipse/1990
Birdman90's Gallery
are there any boxes that are closer to the size of our battery?
Birdman90 is offline   Reply With Quote
Old 04-05-2002, 06:34 AM   #10
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
GST97ORL's Gallery
You can probably check the auto stores for battery boxes. I know I've seen them at PepBoys, but from what I've seen, the quality of them is not very good. The plastic is much thinner, not as resistant to melting or bending, and the overall build quality is lower than the box I got from Summit. If you HAVE to have something closer to the battery's size, that's where to go...just dont expect the same quality.
Old 04-05-2002, 07:17 AM   #11
psyjoniz
Super DSMtalker
96 eclipse rs
psyjoniz's Gallery
what was the reason for you guys relocating your battery?... just curious
psyjoniz is offline   Reply With Quote
Old 04-05-2002, 07:50 AM   #12
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
GST97ORL's Gallery
The battery, being as heavy as it is, can offer a little better weight distribution if it is moved to the trunk, especially if you have no spare tire like me (I removed it for weight reduction, and replaced it with a can of fix-a-flat, and there's more room to store stuff there now). The car tends to handle a little bit better now.
Old 04-05-2002, 02:18 PM   #13
slipspeed
DSMtalker
06 Volvo S40 T5
slipspeed's Gallery
This has me curious as well. As far as weight distro goes, wouldn't a FF want to keep the weight over the front tires? I suspect moving the battery to the trunk would contribute to more weight transfer to the rear and less grip in the front on a launch.
I can see the benifit, however, if you want to alter the weight for handling reasons rather than drag setup, no?
I also think it's the AWD guys that like this mod more.
Has anyone had the car corner weighted after this? Does it fight understeer all that much? I wonder because the battery sits so far on the passenger side. I want to know the weight of the car at all for wheels to see if this would provide more neutral steering.
RN
Current ride: 06 Volvo S40 T5
Former rides:94 RX-7 R2, 97 GS-T, 96 TSi POS w/ a walkin crank
slipspeed is offline   Reply With Quote
Old 04-06-2002, 02:46 PM   #14
GST97ORL
Ultra DSMtalker
Blue 91 TSi FWD
GST97ORL's Gallery
Like I said, since I removed the spare tire, I wanted to keep some weight in the back...so along with my bandpass box, the battery keeps the car a little more balanced.
Yes, you're right I don't do it for a drag setup, I do not race. I however enjoy the additional handling benefits this has afforded me. Before the battery went into the trunk, the rear of the car was very light. But upon the addition of the relocated battery and the new bandpass box, the rear sits a bit more stable now and doesn't bounce around like it used to. The results have been tangible, so I know it must be working.
Old 04-08-2002, 04:44 PM   #15
FaRd0wN
DSMtalker
1990 Talon TSi AWD
FaRd0wN's Gallery
i want to relocate my battery just because the damn thing gets in the way all the time when i am under the hood. as much as i love taking it out everytime i think having it in the rear would be convenient.
http://www.tsiawd.com
FaRd0wN is offline   Reply With Quote
