Apexi Auto timer help - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > Parts/Vendor Discussion Area > Parts Talk
Notices
Old 05-04-2002, 04:57 PM   #1
Tx97GSX
DSMtalker
97 Eclipse GSX
Tx97GSX's Gallery
Hey I just installed the Apexi Auto timer and it's working great. I was wondering if anyone else has this turbo timer and they could help me setting up the A/F value and the O2 Sensor Voltage. I did a search and I wasn't able to find any help on setting these 2 features up. Should I just leave it defaulted to what it has? Will that be a acturate reading?? Thanks for anyone that can help out.
-Tx97GSX
Tx97GSX is offline   Reply With Quote
Old 05-07-2002, 07:41 AM   #2
Tx97GSX
DSMtalker
97 Eclipse GSX
Tx97GSX's Gallery
So no one on this forum has a auto timer that can help me out???
Old 05-07-2002, 09:25 AM   #3
SlowUglyDSM
DSMtalker
1998 Mitsubishi Eclipse
SlowUglyDSM's Gallery
I left the default settings as it is when I got it. You shouldn't have to adjust it or anything as long as it displays the correct value. It works fine and accurate as least for me.
Hope this help.
SlowUglyDSM is offline   Reply With Quote
Old 06-05-2002, 08:00 PM   #4
gs-t95dsm
95 GS-T
gs-t95dsm's Gallery
Thoughts on the timer
What do you guys think of the Apex-i unit? how hard was the install with out the harness, had any problems?
gs-t95dsm is offline   Reply With Quote
Old 06-05-2002, 08:39 PM   #5
Tx97GSX
DSMtalker
97 Eclipse GSX
Tx97GSX's Gallery
Easy install without the harness. Works pretty good
Old 10-28-2002, 05:40 PM   #6
sleeper
1990 Mitsubishi Galant
sleeper's Gallery
Tx97GSX.....
were u able to have the auto timer hooked up to ur aftermaket alarm so u can arm ur car while the turbo timer was still on????
sleeper is offline   Reply With Quote
Old 10-29-2002, 04:46 PM   #7
updoc21
1992 AWD Laser RS
updoc21's Gallery
I have that new timer and it actually does a good job of giving a value close to what the proper a/f mix is. I usually dont use the ratio though, I use the O2 sensor voltage values for tuning. I have seen cars on dynos that graph the a/f mix and the apex TT seems pretty damn close. Basically I have mine set to 11. Most cars want a little higher than that but I am having massive fuel delivery issues due to the cold weather here in pa. At a ratio of 11:1 it is still a little rich but whatever. I have it tapped into the kick panel O2 voltage output harness rather than the ecu as the pin connections on the wiring diagram for the apex unit was incorrect. I wouldnt really rely on the ratio that much, I just have it set to that to see a green light light up at WOT (it's a psychological thing I guess) . Basically the unit uses the same technology the LED a/f guages use but it is a little easier to interpret due to numeric values versus little lights. Hope this helps. Lata
Bill K
PhillyDSM
updoc21 is offline   Reply With Quote
Old 01-17-2003, 01:20 AM   #8
EcLIpsInEmCEe7
DSMtalker
1997 Eclipse GS-T
EcLIpsInEmCEe7's Gallery
what is the the default settings for the A/F ratio and the o2v? when i put in in, i was movin the things around and need to set it to the default, im gettin wack readings. TIA
-matt
EcLIpsInEmCEe7 is offline   Reply With Quote
Old 01-18-2003, 02:47 AM   #9
SidozeGST
DSMtalker
white '99 gs-t
SidozeGST's Gallery
i get wack readings, my fuel ratio sticks at 20 sometimes haha....
my timer works awesome tho...i got the timing part set to 3H3
http://www.dsmtuners.com/gallery/dat...c03313-med.jpg
therse a pic of my install. hopefully someone will explain to me what to do with the A/F and o2 part...didnt even know it had options haha
SidozeGST is offline   Reply With Quote
Old 01-19-2003, 04:55 PM   #10
RochNY91TSI
Hardcore DSMtalker
91 AWD TSI / 05 LGT
RochNY91TSI's Gallery
Anybody have a vfaq for this install yet? I have the timer laying around but I haven't had a chance to install it yet. If nothing exists, maybe I'll make one
Dyno Numbers:
248AWHP, 241ft/lb (Before Rebuild) --Small 16g + Cat
??AWHP After Rebuild... Stay Tuned
RochNY91TSI is offline   Reply With Quote
Old 01-20-2003, 11:12 AM   #11
4g63 Racer
Eagle Talon Tsi AWD 96'
4g63 Racer's Gallery
the blitz is a really good one, thats what I have and its awsome, it has everything.
4g63 Racer is offline   Reply With Quote
Old 02-05-2003, 12:49 PM   #12
noreaga0221
Ultra DSMtalker
1990 eclipse gst
noreaga0221's Gallery
Feedback Score: 1 reviews
i got the tt and the harness but i don't know where the harness is that this harness plugs into? is it in the steering column? under the dash?
2002 c230 coupe.
noreaga0221 is offline   Reply With Quote
Old 02-05-2003, 02:02 PM   #13
RochNY91TSI
Hardcore DSMtalker
91 AWD TSI / 05 LGT
It's under the dash, you have to dig around a bit to find it but it will only fit one of the harnesses under there
Dyno Numbers:
Old 02-05-2003, 02:15 PM   #14
noreaga0221
Ultra DSMtalker
1990 eclipse gst
thanks i found it. its hidden behind the floor hvac vent. i took them out and theres like 4 harnesses behind it. now i gotta figure out why my ebrake shut off wont work.
2002 c230 coupe.
Old 03-14-2003, 04:37 PM   #15
talon97tsi
DSMtalker
talon97tsi's Gallery
Does anyone have a vfaq for this?? I really need a lil help. I do not have the greddy harness. I only have the wires coming from the back of the TT. I bought it from ebay and hope this is what it comes with. I am in the process of soldering up mySAFC 2 LE and would like to do this at the same time, but I do not know which wire go where. I know i sound like an idiot. I have wired to the ecu before many times but never the ignition. Please help
Chris
talon97tsi is offline   Reply With Quote
