How to? Do it yerself cv joint replace? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 07-16-2002, 10:19 PM   #1
sab4you
Hardcore DSMtalker
1998 Honda Accord Coupe
sab4you's Gallery
Anybody have good instructions on a poor guy trying to do my own CV Joints?
Is it a hard job, or can the weekend mechanic do it? I have worked on engines before, but not familiar at all with suspension stuff, so please be descriptive in where stuff is lol
sab4you is offline   Reply With Quote
Old 07-16-2002, 10:43 PM   #2
Turboholic
Hardcore DSMtalker
91-Talon TSI-AWD
Turboholic's Gallery
-It would be much easier just replace the entire axel. http://www.dsmtalk.com/forums/showth...threadid=56535 , if only the boot is broken and the CV joint is still good, you can get those special boot that open on the side, don't need to remove the axel if use those boot.
-Kevin.
Turboholic is offline   Reply With Quote
Old 07-17-2002, 12:47 AM   #3
venom42
Ultra DSMtalker
1990 TSI AWD
venom42's Gallery
I have been told that those split replacement boots do not hold up well. If you go that route (any parts place has them), make sure the boot surface is perfectly clean before you seal it up. If you are going to pay to have it done, order an axle from www.raxles.com, and just pay the labor. It actually comes out about the same overall as if you just have the boot replaced, and you get a whole new axle!
Happy endings are just stories that haven't finished yet.
I gotta snap a new pic.... this one is outdated.
~Mike - venom42@bellsouth.net
venom42 is offline   Reply With Quote
Old 07-17-2002, 03:59 AM   #4
barney
03 EVO VIII
barney's Gallery
Yeah, don't use a split boot. They are intended for emergency use only (VW may be the exception).
There is a complete section on this at www.vfaq.com - look under the drivetrain section. There's a couple of things I would add. First, mark all the parts with a punch before disassembly so they can be indexed the same at assembly for balance. Second, I don't recommend leaving the inner end of the axle on the tranny. Its just too hard to work on that way.
barney is offline   Reply With Quote
Old 07-17-2002, 09:30 PM   #5
Turboholic
Hardcore DSMtalker
91-Talon TSI-AWD
-& have a catch pan ready, fluid will come out once the axel is out.
-Kevin.
Old 06-24-2003, 03:51 PM   #6
talon94es
Super DSMtalker
talon94es's Avatar
1994 Eagle Talon ES
talon94es's Gallery
Feedback Score: 1 reviews
So if I order my axels from these guys it will come with all four rubber boots I need also? I need to get mine done and I might as well have new axels if you say it's about the same $ since my mechanic is doing the work. Thanks, Chris > Old post but plz reply. Thx
*It used to be good but now It's all Great*
(GONE BUT NOT FOGOTTEN)
94 Talon ES w/ Injen Intake ,Mitsu Gas Performance Struts
Performance Brembo Brake Rotors and High Quality Pads, Matrix Front
upper Strut Twr Bar/RRE Rear Strut
Bar, Aftermarket 2.5 Cat-Back w/
Magnaflow Muffler, |
ROLLING:2K5 JETTA GLI
talon94es is offline   Reply With Quote
Old 06-24-2003, 04:36 PM   #7
venom42
Ultra DSMtalker
1990 TSI AWD
venom42's Gallery
When you get the axles, they come fully assembled (including boots). All you do is remove the old ones and install the new ones. Raxles uses synthetic grease in theirs as well.
Old 06-25-2003, 05:08 PM   #8
Deusxmachina
Super DSMtalker
'92 Talon AWD
Deusxmachina's Gallery
Yeah, replacing the entire axle is MUCH easier and is worth the cost. Wherever you buy from, make sure it has a lifetime warranty on it. I've had to take an axle or two back to Autozone or wherever in the past due to another problem causing its demise, and they gave me new ones with no questions asked. It's nice only having to pay for replacement parts once.
Deusxmachina is offline   Reply With Quote
Old 06-25-2003, 10:27 PM   #9
talon94es
Super DSMtalker
talon94es's Avatar
1994 Eagle Talon ES
talon94es's Gallery
Well, I'm not doing the work my mechanic is. So, I might just replace the boots since mine aren't making that much tick/crunch sound quite yet. I looked at them yesterday and all of them are dried up and cracking. So, I'm assuming it would be cheaper to just replace the boots and not the Axels. Wouldn't it end up costing about $100 or more extra to replace the axles also? Thanks again! Chris
Heck, I'm just surprised I was able to put 33K on my car before needed them done since I bought it at 99K.
Old 06-25-2003, 10:55 PM   #10
venom42
Ultra DSMtalker
1990 TSI AWD
venom42's Gallery
The whole point of us telling you to replace the axles is because the labor on replacing the boots is longer than the labor to replace the axles. So the cost is going to be about the same (or at least close) either way. If you have to pay the same, why not get a whole new axle instead of just new boots?
Old 06-25-2003, 11:47 PM   #11
talon94es
Super DSMtalker
talon94es's Avatar
1994 Eagle Talon ES
talon94es's Gallery
Ah, thanks for the clarification on this venom42! I'm going to order mine from www.raxles.com since they have all the boots and seem like good quality. Unless you guys think I should just get some at autozone? Thanks again.
Old 06-25-2003, 11:57 PM   #12
Deusxmachina
Super DSMtalker
'92 Talon AWD
The autozone ones are fine. I think they're like 60 or 80 bucks. And like I said, the lifetime warranty can save you that amount of money again the next time. I had the bolts for the mounting bracket come off on the driver's front axle and it ruined it, but they gave me a new one (after having it only three months) no questions asked. Saved me $60+ right there. I don't know if raxles has a lifetime warranty or not, but there's nothing wrong with the Autozone or Advanced Auto or whatever ones.
Old 06-26-2003, 12:07 AM   #13
venom42
Ultra DSMtalker
1990 TSI AWD
venom42's Gallery
Although I am sure the Autozone ones are fine, Raxles only uses new outer joints. I can almost assure you that the Autozone ones are reconditioned. If the price is close, go with Raxles. If they are way cheaper, then go with Autozone. If I remember correctly, they were pretty close in price when I did one of mine.
Old 06-26-2003, 11:55 AM   #14
barney
03 EVO VIII
barney's Gallery
I've replaced boots a couple of times now - one axle three times. My CV joints don't have any play at all after 90,000 miles - they are just like new. I can't see sending in an axle like this as a core because the boot is shot. Just my opinion
