Suposivly Deep Cycle battery's have (or did) a memory. Meaning they remember when they are charged. If they are charged at the same point often enough, they think when they are below that charge level, they are dead. So if you use a deep cycle battery as your main, you could have problems with the car not starting, even though the battery has more then enough juice left in it.
-Jon-
Speed kills, drive Hondas live forever!
they have fixed this with items such as rechargable batteries and cellular phones i would think that would be a huge problem, sense the alternator is constantly recharging the battery? if you had the radio on for 10 or 15 minutes without running the car it would then in theory not start because it would think that there is no juice?
I've used an Optima Yellow Top as my main and only battery for 4 years now. Keep in mind I have a stock charging system and 1/0 AWG wire running to a Rockford Punch 360a2 and Power 800a2. It has never let me down and I haven't yet had to replace it after four long years of bumpin' sometimes with the car off for 20 minutes at a time. I can watch a whole DVD in my car at normal listening volume with it off and still have plenty of juice left to start it. I've accidentally left my door partially open, left the DVD player on over a couple days time with no driving, etc. Ran the battery all the way down. Charge it up, drive the car, and it is just fine again. Takes a lickin and keeps on tickin. My personal opinion: this battery kicks ass.
I've had my Yellow Top Optima about 16-18 months now. No problems whatsoever. No leaking. Nothing. It's one helluva battery. I kept going through the stock Mitsu batteries like every other 6-7 months. They all leaked like crazy. No more headaches with the Yellow Top Optima now. Plus, I can pretty much listen to music even when the car's not running without worrying about running the battery down. Highly recommend it. I paid $190 for mine.
I'm pretty sure the problem is fixed now. That's why I said supposedly. I've never heard of a Yellowtop failing because of that. But if you want it to be warrantied, you can't use it for a starting battery. You should use a red top if you only get use one battery. If you add a second, then use a Yellow top.
-Jon-
I was told by an Advance auto employee that the yellow tops will not fit in a eclipse or talon, therefore resulting in me buying the red top. That pisses me off because I am upgrading my system and need that extra power. No problems yet with the red top I love it but I would prefer the yellow.....
red is just a little bit cheaper (liek 20-30 dollars) then the yellow but i cant figure out how to say it..it has "less power" or something, so you cant sit in your car as long with stuff on, it still is a very long time though
95' TaloN TSi : slightly modded
the yellow is a deep cycle battery that is gel filled and is made more for systems and more power output. The red top is a good starting battery, not a bad battery.
If you are considering a optima battery, you should also look into the stinger batteries. They make all shapes and sizes of them and they are very good batteries.
yes the stinger batteries are good also, I just am able to get optima batteries on discount. The red top is a very good starting battery as it lists in its info. I have never had starting problems, leaking problems, they last for a long time without the engine on and will jump start like any other battery and recharge great. A good investment and will save you money in the long run in my opinion.
