Dejon tool SMIC - Page 2 - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > Parts/Vendor Discussion Area > Parts Talk
Notices
Old 11-08-2002, 03:34 AM   #16
mpratt95
DSMtalker
95' TalonTSI
mpratt95's Gallery
Just my 2 cents, but the Supra sidemount wasn't that hard to install. The trouble I ran into was the fact I didn't have the stock 2 1/2 inch stock rubber elbow that came on the I/C. The supra sidemount is HUGE compared to the stocker...I think over double the size. Anyway...I will be posting a review shortly on my install, and a couple of mods I added that I think will be beneficial. I would almost say the install was easy.
95' Talon fwd: Big28 (ported), Extreme/Thermal 3" turbo back (no cat), upper/lower IC pipes, 1g BOV, Supra sidemount, MSD 8.5mm's, FFWD MBC, ported manifold/o2, Walbro 255lph high pressure pump, Injen intake/K&N....um...I think that's it.
mpratt95 is offline   Reply With Quote
Old 11-08-2002, 07:28 AM   #17
Grizzly
DSMtalker
1G
Grizzly's Gallery
Feedback Score: 1 reviews
i just bought a Dejon 1G sidemount upgraded IC.
it is the 1G stock intercooler with 2.25" inlet and outlets welded on.
this IC does NOT bolt right on.
the lower engine support bar that holds the front motor mount is in the way of the IC.
the IC's lower inlet pipe hits this support bar. i had to cut the support bar lip off and then cut back lengthwise about 4". and then i beat the metal in with hammer.
this was the only way i could get the IC pipe to fit properly and be able to get a coupling over the inlet pipe.
i have yet to test out the car with the pocket logger.
Grizzly is offline   Reply With Quote
Old 11-08-2002, 02:33 PM   #18
joereitman
Hardcore DSMtalker
Plymouth Laser RS Turbo
joereitman's Gallery
Grizzly- do you have awd? I am fwd and it works fine. Maybe that is the difference? Of course, I modded my own stocker, but maybe there is indeed a difference between the 90 and later years?
Joe
John 3:16; John 14:6
www.dsmabc.com
Orig Owner, 73K, Ram Air, K&N's, MAS Mods, 1.25" Cold Air MAS Bypass, Ported Big 16G, Propane Injection, Custom 2.5" LICP, SMIC with 2.25" in/out, Brode 2.5" UICP and Elbow, 2.5" Mandrel Side Exit Exhaust, CFDF, 190 LPH Rewired , Autometer A/F and 30-0-30 Boost Gauge, Pocketlogger, Eibach, KYB, Rear ASB and Strut Bar, 225 Yoko AVS, 16x7's, ~2582 lbs, 3A40BC Fire Extinguisher.
9.286@84.79 (2.429 60' )
joereitman is offline   Reply With Quote
Old 11-08-2002, 05:55 PM   #19
Grizzly
DSMtalker
1G
Grizzly's Gallery
Joe
yes, i do have the AWD. now that you mention that, i dont think the FWD has that front support.
so the install should be no problem on a FWD..... but a pain in the ass on a AWD
Old 11-08-2002, 06:30 PM   #20
joereitman
Hardcore DSMtalker
Another thought- Dejon has come up with a pneumatic sytem to stiffen and raise the rear of the car for better traction, a FWD trick, so maybe their shop car is FWD?
I don't have an engine support in close proximity to the ic.
Joe
www.dsmabc.com
Old 11-08-2002, 07:15 PM   #21
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
Feedback Score: 2 reviews
It is not any harder on an AWD than a FWD. The diference from the 90 IC is it doesn't have the extended inlet pipe on the bottom, it has a short, straight in connection whereas the 91-93 have a bend and extension on them. If there are any other differences, somebody please point them out. Anybody who thinks installing a Supra IC is a pain in the ass obviously has no patience or the proper tools or knowhow/mechanical ability to get it done properly. Mine looks stock and wasn't hard at all with proper planning and some minor cutting.
RippinGSX is offline   Reply With Quote
Old 11-08-2002, 07:19 PM   #22
joereitman
Hardcore DSMtalker
"the 91-93 have a bend and extension on them"
So does my mid year 90...
www.dsmabc.com
Old 11-08-2002, 07:20 PM   #23
91eclipsegsx16boy
1999 Eagle Talon
91eclipsegsx16boy's Gallery
i bought some 2.5" intercooler pipes (upper AND lower), bigger turbo outlet, and 2.5" throttle body elbow- for $150
so I figured 2.5" Lower IC pipe to a 1g 1-3/4" inlet would be a waste, so I had Indy Race Cores mod my 1g SMIC for 2.5" in/outs to match the pipes nicely
I noticed a ~4psi increase without touching the MBC (over stock piping+SMIC). After turning the boost down to ~16, with the piping, SMIC, and K&N, I was able to chirp the 1-2 shift (stock clutch) regularly, and noticed the water temps were much more stable than before the SMIC+pipes.
-aaron
91eclipsegsx16boy is offline   Reply With Quote
Old 11-08-2002, 11:33 PM   #24
V8s_are_slow
Hardcore DSMtalker
1991 Eclipse GS-T
V8s_are_slow's Gallery
Feedback Score: 4 reviews
if i was gonna get a sidemount for a 2g, it would be the one from hahn's. nice big i/c (bigger than dejon's anyway), don't have to hack up any metal or anything for install, and still good for up to 400 horsepower. if i was going for more power than that, i'd go for a frountmount anyway....which of course i'm shooting for around 600hp so this discussion doesn't really apply to me. just throwing in my 2 cents.
scott
V8s_are_slow is offline   Reply With Quote
Old 11-09-2002, 01:12 AM   #25
IronPalm
DSMtalker
97 Mitsu Eclipse GS-T
IronPalm's Gallery
I'd been curious about the Hahn sidemount IC as well, but have decided to try the Supra side mount, seems like a much better dollar to hp ratio
IronPalm is offline   Reply With Quote
Old 11-09-2002, 08:01 AM   #26
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
You won't be sorry. As long as you put in the time and effort it will look and perform sweet
Old 11-09-2002, 11:55 AM   #27
NOMIEZVR4
Ridiculous DSMtalker
NOMIEZVR4's Avatar
2005 ZX-10R
NOMIEZVR4's Gallery
Feedback Score: 10 reviews
well mine is fwd and we wer trying to put another ic from my cousins 92 awd. it didn't fit, even the lower pipe was different. man, i have to make myself upper and lower ic pipes...
NOMIEZVR4 is offline   Reply With Quote
Old 11-09-2002, 01:46 PM   #28
GSXtreme.org
1993 Talon TSI AWD
GSXtreme.org's Gallery
I heard it dangles so low that a road debre will take it off.
GSXtreme.org is offline   Reply With Quote
Old 11-09-2002, 02:11 PM   #29
RippinGSX
Honorary Moderator
RippinGSX's Avatar
1993 Eclipse GSX
RippinGSX's Gallery
You heard wrong. Once again, if installed with patience and time it looks stock. Mine hangs down about a half to three quaters of an inch more than the stock IC did.
Old 11-09-2002, 03:24 PM   #30
GSXtreme.org
1993 Talon TSI AWD
We need a comparison of all these SMIC.
