1g RPM to Speed calculator - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 11-19-2002, 09:50 AM   #1
TigerWoodsJr
DSMtalker
1990 Eagle Talon TSI
TigerWoodsJr's Gallery
I have seen it around, but don't remember where it was, you can plug in your RPM in 5th gear and it calculates the speed, since the stock speedo stops at 145....im having a debate on a college board about the 1g's not being able to do more than 145...thanks guys.
Please read the rules.
TigerWoodsJr is offline   Reply With Quote
Old 11-19-2002, 08:54 PM   #2
dsmawdturbo
Hardcore DSMtalker
92 Eagle Talon tsi awd
dsmawdturbo's Gallery
i know the fwd correct me if im wrong are geared to 176...then u hit the rev limiter i know the awd can't be far off me personally ive done 140 and i know it coulda went higher than 145.
Evo3 turbo 17-20 psi + o2 and mani, keydiver, 255lp,750cc inj,afpr,maf-t, 3 inch exhaust,
dsmawdturbo is offline   Reply With Quote
Old 11-19-2002, 09:17 PM   #3
joereitman
Hardcore DSMtalker
Plymouth Laser RS Turbo
joereitman's Gallery
gearzone.net- autodyne RPM calculator.
If you input the stock gear ratio (4.11 I believe) and 5th gear ratio (you need to look this up) and input tire size, it will give you speed at desired RPM.
Or, take speed at 3750 in 5th and multiply by two, assuming stock speedo is calibrated and the car has the hp to top out 5th and has the stock rev limiter.
Joe
John 3:16; John 14:6
www.dsmabc.com
Orig Owner, 73K, Ram Air, K&N's, MAS Mods, 1.25" Cold Air MAS Bypass, Ported Big 16G, Propane Injection, Custom 2.5" LICP, SMIC with 2.25" in/out, Brode 2.5" UICP and Elbow, 2.5" Mandrel Side Exit Exhaust, CFDF, 190 LPH Rewired , Autometer A/F and 30-0-30 Boost Gauge, Pocketlogger, Eibach, KYB, Rear ASB and Strut Bar, 225 Yoko AVS, 16x7's, ~2582 lbs, 3A40BC Fire Extinguisher.
9.286@84.79 (2.429 60' )
joereitman is offline   Reply With Quote
