rear wheel drive eclipse? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Closed Thread
Old 06-05-2003, 03:24 PM   #1
teamKAOSdSM
1993 Eclipse GS
teamKAOSdSM's Gallery
my friends and i were thinking about things(doesnt happen often)
would it be possible to make a AWD TSI or GSX into RWD.
what we were thinking is just taking off the front drive shafts, would this work, are we all crazy?
teamKAOSdSM is offline
Old 06-05-2003, 03:31 PM   #2
MNGSX
1996 ECLIPSE GSX
MNGSX's Gallery
You'd need to do more than that.
Do that and you will just fry a vcd.
You'll need to put a spool in your center diff and either weld the VCD or get the parts to eliminate it from TRE.
MNGSX is offline
Old 06-05-2003, 03:36 PM   #3
teamKAOSdSM
1993 Eclipse GS
ok so VCD = viscouc coupler rihgt, whats the TRE, and with those things done would it work, i suppose i would probably need to know exaclty how the AWD in a TSI or GSX works before i can do anythign like that.
Old 06-05-2003, 03:37 PM   #4
MNGSX
1996 ECLIPSE GSX
MNGSX's Gallery
Go to the main page and click DSM vendors.
TRE is a eclipse drivetrain parts vendor.
MNGSX is offline
Old 06-05-2003, 03:41 PM   #5
teamKAOSdSM
1993 Eclipse GS
ok so eliminating the VCD would take it from AWD to straight 50-50 front rear, then from there i could just take off the front shafts?
the thing that was talked about from TRE, is that the same as the viscous coupler eliminator from machv.com?
http://www.machv.com/viscoupel.html
Old 06-05-2003, 03:57 PM   #6
MNGSX
1996 ECLIPSE GSX
MNGSX's Gallery
http://www.teamrip.com/awd.html
The eliminator is not the same thing.
They accomplish the same goals but there are no welds to worry about on the eliminator.
Also note the spool for the center diff and the welded center diff option.
You could also cut the beam on the front CV shafts and install quick disconects like they sell for flat towing FWD cars behind motor homes. Then you'd have really quick selectable AWD/RWD with a 50/50 split.
The only thing I'd worry about is the ring gear on the center diff when you go RWD with alot of power.
The best way to RWD drag setup a AWD eclipse would be going longitudinal with a powerglide auto or lenco manual and use a vette (Older) rear differential and custom axles to the spindles.
MNGSX is offline
Old 06-05-2003, 04:17 PM   #7
99gsxturbo
DSMtalker
99 Eclipse GSX
99gsxturbo's Gallery
i could be way off here, but to me it seems like you would be breaking drivetrain components everyday because 100% of the power is going to the rear and not being distributed to the front to take some of the load off.
99gsxturbo is offline
Old 06-05-2003, 04:24 PM   #8
MNGSX
1996 ECLIPSE GSX
MNGSX's Gallery
Yes it would be weak.
I'm saying it's possible to do it that way but weak.
I'd just keep AWD or do longitudinal.
MNGSX is offline
Old 06-05-2003, 04:29 PM   #9
teamKAOSdSM
1993 Eclipse GS
so the rear wheels wouldnt get all the power? in what way would it be weak?
is there any way to adjust the VCD, cause i know in the new WRX sti its a adjustable center diff, where you can put all the power to the rear wheels(or almost all of it), i think some skylines are like that too, i was just wondering, casue AWD is amazing on the wholeshot, but in the long run it isnt as fast as a RWD car would be when moving.
Old 06-05-2003, 05:03 PM   #10
ChicagoGSX
Hardcore DSMtalker
95 GSX
ChicagoGSX's Gallery
The rear end is only meant to take 50% of the power, but with RWD you'll be putting it all through it. It may not be strong enough to take it. Not to mention the fact that since the wheel wells are small on our cars you won't be able to get much tire under there so traction will be a problem.
1995 Eclipse GSX
Ported 16g w/34mm Flapper/Apex'i S-AFC/ATR Exhaust and Downpipe/Dejon Tool 2.5" intake and K&N/1g BOV/ACT 2100/Boost and EGT Gauges/Ported 2G O2 Housing and Manifold/Walbro 255/Fluidyne Radiator/HRC FMIC & Piping/550s
ChicagoGSX is offline
Old 06-05-2003, 11:21 PM   #11
teamKAOSdSM
1993 Eclipse GS
ahh ok, so woudl there be a swap, maybe a rear diff from a 3000gt vr4 or somethgin that woudl be able to handle more power, or is this a waste of time?
Old 06-05-2003, 11:32 PM   #12
damnslowtalon
damnslowtalon's Avatar
Bimmer
damnslowtalon's Gallery
I just don't see what the benefits would be. I like not having to worry about traction problems.
-Jim
damnslowtalon is offline
Old 06-06-2003, 01:52 AM   #13
BICTURBO
Spyder GST
BICTURBO's Gallery
ASk dave buschur about the benefits of a RWD conversion he has some timeslips or something
BICTURBO is offline
Old 06-06-2003, 01:08 PM   #14
MITSUMAN
'91 Eclipse GSX
MITSUMAN's Gallery
i think it would be sweet to see a eclipse/talon drifting. the only thing is our axles are way to breakalbe. even with the four bolt upgrade they are to fragile for that kind of power.
MITSUMAN is offline
Old 06-06-2003, 04:28 PM   #15
taz2w
90 GS-t
taz2w's Gallery
If you are doing all that work what about a Ford rear end. You will not break one of those.
taz2w is offline
Closed Thread
