MCCC vs Amsoil Engine Flush?? - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 06-12-2003, 12:42 AM   #1
Keaka26
Ultra DSMtalker
'07 Chevy Corvette
Keaka26's Gallery
Feedback Score: 1 reviews
Is the Amsoil Engine flush the same thing as the Mopar Combustion Chamber Cleaner? Will I get the same results, because MCCC is hard to come by these days. I read on MCCC that you spray into the PCV nipple on the intake then put 1/4 of the can in each cylinder and let that soak for quite a few hours.
Is this process identical to the Amsoil flush??
Thanks in advance.
Keaka26 is offline   Reply With Quote
Old 06-12-2003, 01:24 AM   #2
markGSX
DSMtalker
1992 Eclipse GSX
markGSX's Gallery
I went by my local dodge dealer and they had several cans of MCCC. Guess I got lucky ?
markGSX is offline   Reply With Quote
Old 06-12-2003, 03:00 AM   #3
DongeR
91 VR-4 #615
DongeR's Gallery
Seafoam is what i used and pretty cheap too.
i can get 300 to a tank but before it was 250. accelleration is better.
DongeR is offline   Reply With Quote
Old 06-12-2003, 03:08 AM   #4
noreaga0221
Ultra DSMtalker
1990 eclipse gst
noreaga0221's Gallery
i sprayed a whole can throw my pcv valve and emptied another whole can into each cyclinder. i let it sit over night then vacuumed out the liquid. before i did this, my egts would shoot to 1600+ at 18psi, untuned car with stock exhaust. now, still untuned though, they dont go higher than 1500.
call you're nearest dodge dealer for mccc. the guy gave me a discount since i bought 5 bottles.
noreaga0221 is offline   Reply With Quote
Old 06-12-2003, 05:32 AM   #5
frontdriver
DSMtalker
91 Tsi FWD
frontdriver's Gallery
Re: MCCC vs Amsoil Engine Flush??
Thanks in advance.
I'm assuming the amsoil goes in the crankcase. This would only flush the parts in contact with the oil. The MCCC is sprayed into the combustion chamber, so this is where the cleaning would be done. So no, you won't get the same results from these two different products.
frontdriver is offline   Reply With Quote
Old 06-12-2003, 11:55 AM   #6
doug
Hardcore DSMtalker
98 GS-T A/T
doug's Gallery
Yes, that is correct. I used the Amsoil engine flush when I first switched to Amsoil engine oil last year. You pour it into the engine, run it for about 10 minutes, then change the oil.
J Doug
2003 Mustang Mach 1
98 Eclipse GS-T *sold*
doug is offline   Reply With Quote
Old 06-12-2003, 05:49 PM   #7
Keaka26
Ultra DSMtalker
'07 Chevy Corvette
Keaka26's Gallery
Ok, I got some MCCC today. But I am getting conflicting instructions. I hear some things are saying to spray the MCCC into the intake pipe through the PCV nipple, others saying to spray into the intake manifold....
Thing is, couldnt the MCCC damage the turbo somehow? Doesnt seem like something that would be good. I dont know how id spray it into the TB because the car wouldnt read through the MAF sensor properly if i disconnected the UIP....
Where do i spray this stuff to clean the valvetrain (not the cylinders part of the process, i understand that part.)
Old 06-12-2003, 06:04 PM   #8
Stephen
Senior Moderator
Stephen's Avatar
1995 Talon TSi AWD
Stephen's Gallery
Feedback Score: 2 reviews
hey man, check out my review
http://dsmtalk.com/forums/showthread.php?threadid=93365
Stephen is offline   Reply With Quote
Old 06-12-2003, 06:56 PM   #9
vlaar
'90 Talon TSi FWD
vlaar's Gallery
Wouldn't it be pretty pointless and a waste of $$$ to use the Amsoil engine flush, if you've been running Mobil 1 10w30 for the psat 20K??? I used Amsoil on my last talon and will be using it again in the next couple weeks I'm the third owner on the talon now and the previous two owners used petroleum 10w30 for the 1st 100K and then the guy switched over to Mobil1. No leaks whatsover and hopefully none will arise with the Amsoil
vlaar is offline   Reply With Quote
Old 06-12-2003, 08:20 PM   #10
dsm1kenobe
DSMtalker
1992 GSX
dsm1kenobe's Gallery
You can spray in either the tb or pcv. I chose the PCV bc it's easier to get to. Make sure to use a funnel when you do it this way. If you do decide to go the tb route, the car will idle even if you pull off the uip and the maf isn't reading correctly.
The only part of the valvetrain you want to clean with MCCC are the valves in contact with the intake air...that's it. if you want to clean the other parts, use motor flush or ATF. MCCC won't hurt your turbo.
dsm1kenobe is offline   Reply With Quote
Old 06-12-2003, 08:51 PM   #11
dsm1kenobe
DSMtalker
1992 GSX
don't forget to change your plugs afterwards, as they will be fouled from running rich and mccc. get 1 degree colder than stock plugs.
Old 06-12-2003, 11:09 PM   #12
Keaka26
Ultra DSMtalker
'07 Chevy Corvette
Keaka26's Gallery
i did the MCCC today through the intake manifold PCV line...Used the whole can as directed...Didnt fix my problem...
Old 06-12-2003, 11:27 PM   #13
dsm1kenobe
DSMtalker
1992 GSX
did it at least lower it?
Old 06-12-2003, 11:37 PM   #14
loreak
92 Eagle Talon TSI AWD
loreak's Gallery
i thought u just cleaned carbon deposits out the cylinders with MCCC while the car was off, so you also spray it into the TB while the car is running to clean things up also?
loreak is offline   Reply With Quote
Old 06-12-2003, 11:42 PM   #15
dsm1kenobe
DSMtalker
1992 GSX
if it's knock you're trying to lower, soaking the piston tops worked moreso than spraying it directly in the intake manny. the latter cleans your intake valves and manifold.
