Tell me what you know about assembling a bottom end! - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 12-12-2008, 11:53 PM   #1
4g64fiero
Ridiculous DSMtalker
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Feedback Score: 27 reviews
I used to half ass building motors. I didnt realize the error of my ways until I started messing with 4g63 engines. I have been own by the 4g63 a couple times for not paying attention to details.
That being said,
http://www.rosspistons.thinkhost.com...STRUCTIONS.pdf
There is some good info in there. What I didnt understand is how do you check piston ring "end gap"?
Then I found this:
http://www.muller.net/sonny/crx/rings/index.html
Makes it pretty simple. So far, now we know how to calculate what end gap we need and how to achieve that.
There seems like there is more as far as adjusting the end gap(like if you are boosting ALOT it seems like it would be best to run a larger gap) than listed. Hopefully, Kmanstsi or someone else that knows alot will chime in.
I used to also just torque my rod bolts to a certain torque with no attention to rod bolt stretch. That is bad. Here is why:
http://www.chevyhiperformance.com/te...nfo/index.html
What I'm not sure aboout is how to check main and rod bearing clearances. Its just the diferance between the size of the journal on the crank and the rod bearing surfaces right?
http://www.circletrack.com/tipstrick.../photo_06.html
Hopefully this will help some people and I will get some info!
No more DSMS, No more EVOs, no more MITSU
4g64fiero is offline   Reply With Quote
Old 12-13-2008, 08:59 AM   #2
kickasskid2087
DSMtalker
kickasskid2087's Avatar
97 Tsi Awd
kickasskid2087's Gallery
Re: Tell me what you know about assembling a bottom end!
Im not really sure about gap when under slot of boost, but as far as rod bolt stretch, I have always made sure the the rod bolt and nut are both clean and DRY, no oil or lube then just tighten the bolt down in fractions( If final torque is 80 ft/lbs- do 30 then 60 then 80). To check you rod and main clearance you will need plastigauge. Install the bearing and do not apply any lube, lay a section of plastigauge across the journal and torque your caps to final torque. No take the caps back off and see how much the plastigauge was stretched, there will be a chart on the plastigauge. That is your bearing clearance. Hopefully this will help
kickasskid2087 is offline   Reply With Quote
Old 12-19-2008, 04:18 AM   #3
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
http://www.carcraft.com/techarticles...ance_tips.html
Some good info there about rod bearing clearances.
Old 12-19-2008, 04:34 AM   #4
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
http://popularhotrodding.automotive....rol/index.html
More good info on bearing clearances.
Not trying to post whore, just posting this shit as I find it.
Old 12-19-2008, 07:58 AM   #5
MidShipCivic
MidShipCivic's Avatar
92 Eagle Talon TSI AWD
MidShipCivic's Gallery
Not if you're putting together an oem engine.
MidShipCivic is offline   Reply With Quote
Old 12-19-2008, 03:55 PM   #6
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Thats the way I USED to do it. Like you implied, its definitely a bad idea. I use a rod stretch gauge now to tell.
Old 12-19-2008, 07:25 PM   #7
blue91
Super DSMtalker
blue91's Avatar
eagle/talon/1991
blue91's Gallery
Feedback Score: 1 reviews
Yep, that's how I did mine, and it turned out well. I actually did this for every 120 degrees of crank rotation, just to check for possible differences around the surface. I figured it was good enough, since all my findings where nearly identical to mfg. specs.
Lacking all the measuring tools a proper machine shop has, I found plasti-guage to work suitably well. This was a fairly basic rebuild, reusing the stock crank and installing new, OEM bearings (leaving less of a chance for varying tolerances).
...Good thread, keep it going.
'91 Talon AWD
// 190lph // 680's //2.5in BR turbo back // Hallman mbc // ACT2100 // SBR street FMIC // 2G ex. man. // small 16g // 2G maf w/custom intake// head port/polish // B/S eliminated //
blue91 is offline   Reply With Quote
Old 12-19-2008, 08:06 PM   #8
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Plasti gauge isnt as accurate as a gauge. But everyone already new that probably.
If your building a motor with really tight or really loose bearing clearances, then there is enough give in the plastigauge to make it too loose or tight, respectively.
Old 06-17-2009, 09:51 AM   #9
tarantula
Ultra DSMtalker
98 Eagle Talon TSi AWD
tarantula's Gallery
Feedback Score: 21 reviews
This is an excellent thread
Sold the legend! Eagle has lifted its wings and flew away.
tarantula is offline   Reply With Quote
Old 06-17-2009, 10:02 AM   #10
Red1991TSI
Site Administrator
Red1991TSI's Avatar
1991 Eagle Talon Tsi
Red1991TSI's Gallery
Feedback Score: 78 reviews
All you 4G63 engine builders throw up what you know. If I see this thread full of win with a lot of participation, I'll sticky it.
Read the rules people!
Red1991TSI is offline   Reply With Quote
Old 06-17-2009, 12:57 PM   #11
PROZIUM451
Super DSMtalker
PROZIUM451's Avatar
96 Talon TSi FWD
PROZIUM451's Gallery
I ALWAYS use a lubricant on the threads, never oil, but something to relieve friction. If you read one of the articles above it explains how torqueing (sp?) is only an estimated measurement of bolt stretch as calculated by the manufacturer. Torque alone is not enough to determine is the fastener is held on properly and preloaded to the correct specifications.
Again, torque is only an estimate of pre-determined mating conditions. Always torque and then check for stretch, and then retorque until proper strech is reached.
"When any government, or any church for that matter, undertakes to say to its subjects, This you may not read, this you must not see, this you are forbidden to know, the end result is tyranny and oppression no matter how holy the motives." - Robert A. Heinlein
10 Hundred Racing
PROZIUM451 is offline   Reply With Quote
Old 06-18-2009, 02:53 PM   #12
mavisky
mavisky's Avatar
1992 Eagle Talon es-tsi
mavisky's Gallery
Feedback Score: 5 reviews
Clevite assembly lube on all bearing surfaces.
Measure all gaps to factory specs.
Feeler gauge for rings - measure at top and bottom, square in bore
plastigauge for bearings - 2 on top, 2 on bottom, then rotate crank 90 degrees
Copper spray + dry gaskets = win
chase threads with taps and dies
Loctite on fasteners that may rattle loose or are vitally important - blue or red depending on how often you'll be servicing
ARP lube for torquing fasteners like rod bolts, main bolts, and head studs
Measure bore diameter with dial calipers if you can't get bore-dial-gauge
That's all I've got for now. I'm sure there are more details, but those are some basics
'95 Black Mustang GT - H/C/I 5.0, 3.73's, suspension mods
'04 Red Eddier Bauer Excursion Turbo diesel - lifted and flashed
'10 Black Forester XT - 17" Enkei's, axle back exhaust - wife wagon
mavisky is offline   Reply With Quote
Old 06-30-2009, 11:42 PM   #13
BaconwalletTsi
Eagle TalonTsi 1992
BaconwalletTsi's Gallery
Dont use STD size rings on an engine with 50k or more miles the bore will have increased and your end gaps will be huge and eng. vacuume low.
And ensure clean clean clean.
BaconwalletTsi is offline   Reply With Quote
Old 07-01-2009, 11:27 AM   #14
SionGrey66
Hardcore DSMtalker
SionGrey66's Avatar
1998 Eclipse GST
SionGrey66's Gallery
Feedback Score: 15 reviews
That would be greatly appreciated Steve, there's already a ton of great info here.
-Aria-
A2SportCompacts
SionGrey66 is offline   Reply With Quote
Old 01-02-2010, 07:25 PM   #15
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Originally Posted by taboo
Don't worry, assembling the bottom end is much easier than it sounds. First you need to prep the block - reverse the front balance shaft bearings (if eliminating the balance shafts = highly recommended), lightly break the edges of the cylinders and mains (if the block was align-honed and decked), deburr and retap (using preferably bottoming taps) every single hole, use bottle brushes to clean the oil gallery and all oil passages in the block. Clean the entire block with soupy water (high-pressure washer works best) over and over - 'til it's squeeky clean. Dry it with towels and compressed air and spray the entire block with WD40 since the cylinder walls and any machined surfaces start to rust almost immediately.
The difference between turning and polishing the crank is in the amount of removed material. If the crank is turned, oversized bearings need to be used. Preferably, one shouldn't have to turn the crank if its journals aren't deeply scored. Have the crank, flywheel, crank sprocket and harmonic balancer perfectly balanced (same with the pistons and rods). You can polish the main and rod journals of the crank yourself, using a strip of 600 grid sandpaper and a long rawhide thong (the sandpaper strip needs to be as wide as the journal, then just wrap the sandpaper around, wrap the rawhide around the sandpaper - two full turn and pull on the ends of the rawhide back and forth to make the sandpaper spin around the journal. Be carfull not to remove any material, just polish the surface of the journal). Once done, clean the oil feeds and the entire crank and spray it with some WD40 to prevent rust.
The rest is just a standard procedure - install the main bearings dry, drop the crank carefully in and use Plastigauge to check the clearances with the mains torqued to specs. If you don't use the ARP studs (unless you're building 500+HP monster), use just the OEM bolts (without the CRCO kit). Once the clearances are checked, take the crank out, lube the mains with assembly lube, drop the crank back in, torque the mains to 10ft.lbs., push the crank toward the front of the block by gently tapping a big screwdriver between the counterweight and the block, tap the cap of the thrust bearing toward the rear of the block, torque all the mains down and remove the screwdriver. Check if the crank spins freely and check the crank endplay. If everything's within specs, assemble the pistons, rings and rods + bearings and insert pieces of rubber tubing on the rod bolts to protect the crank from getting scratched. Oil the entire pistons and carefully install the piston/rod assemblies using a suitable ring compressor while making sure you don't nick or scratch the cylinder walls and/or the crank journals. Check the clearances of the rod bearings with Plastigauge (dry) while torqued to specs, then take them apart again and lube them (just like the mains). Torque the rod bolts to specs, rotate the entire assembly and check the clearances beween the rods and the crank.
That's roughly all there's to it..
What a fucking epic post.
Thats the procedure to align the gurdle to set thrust play correctly!
I didnt do this on my last build and I had a destroyed crank and thrustbearing in less than 1500 miles on my 95 seven bolt.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
