Tell me what you know about assembling a bottom end! - Page 4 - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Notices
Old 10-27-2012, 12:02 AM   #46
90BLACKAWDTSI
Hardcore DSMtalker
90BLACKAWDTSI's Avatar
1996 auto AWD Talon.
90BLACKAWDTSI's Gallery
Re: Tell me what you know about assembling a bottom end!
It is not hard to assemble the engine as that is the easy part. The hard part is knowing how to use proper measuring devices to be absolutely certain you have your clearances within specifications.
I personally just built a Evo VIII motor Wednesday, Put it in the car thursday and with the engine having about 5 miles on it breaking it in just made 862AWHP at 42 PSI.
Finding a set of clearances that work is the hard part because unless you have someone that is already knowledgeable on 4g63's and can tell you what clearances should be used for x amount of HP then most people have no clue what to do.
You may ask what clearance's am I running for a 900whp 4G63?
.005" PTW
.0025" Main bearing oil clearance
.0035" Rod bearing oil clearance
I am running a much larger rod bearing clearance due to the fact that I am running aluminum rod's. Clearance for steel rods will be .001" smaller in most cases.
I only use Brad Penn 20w-50 and it gets changed after every track event.
90BLACKAWDTSI is offline   Reply With Quote
Old 12-11-2012, 08:50 AM   #47
4g64fiero
Ridiculous DSMtalker
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
Feedback Score: 27 reviews
.005" PTW
What do you use to measure?
Also, great point about oil clearance. Normally, the manufacturer of the internals has the specs so the assembler doesnt always need to blow up a couple motors before he/she figures it out.
No more DSMS, No more EVOs, no more MITSU
4g64fiero is offline   Reply With Quote
Old 04-14-2013, 01:53 PM   #48
cupa-joe
Ultra DSMtalker
cupa-joe's Avatar
Galant Vr-4
cupa-joe's Gallery
Feedback Score: 3 reviews
Something that I think is relevant and haven't seen yet. Say you build a long block and its going to sit for a little before its first start, is there anything that needs to be done to maintain it until its first start? Ex: put oil/WD-40 in the spark plug wells and rotate crank etc...
What do you guys do or recommend?
8.5:1 Mahle/Scat | 7 blade HX40 (BEP .55 A/R) | Evo3 manifold |Cyclone Intake | SBC 2700#/4-puck ceramic | DKS 272 | VRSF FMIC | 3" Side exit | Walbro 450 | Bosch High-Z 2200cc | BR9ES @ .032" | Flex fuel (E85) | DSMlink V3 (SD)
FULL BUILD SPEC SHEET ===>GVR4 1242/2000
cupa-joe is offline   Reply With Quote
Old 04-14-2013, 02:32 PM   #49
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
Feedback Score: 7 reviews
I would open up the plug holes, spray a healthy amount of wd-40 in there, make sure the crankcase has oil in it and seal it in a bag also soaked in wd-40.
99 Spyder "GSX"
Sean Clancy
Sean485 is offline   Reply With Quote
Old 04-14-2013, 07:25 PM   #50
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
Feedback Score: 9 reviews
When I assemble an engine for long term storage I use STP oil additive for assembly lube, and coat the cylinder walls, valve stems, seats, inside the crankcase, cams, rockers, etc. If it's only going to be sitting for a month or so I like to use a 50/50 mix of STP and oil, or if it's going to be run right away I just use oil.
10HR OPR BSMR NAFPR
DSM Loki is offline   Reply With Quote
Old 04-14-2013, 07:54 PM   #51
90BLACKAWDTSI
Hardcore DSMtalker
Forgot all about this thread. I only use Dial bore gauges and Micrometers.
Old 04-14-2013, 09:24 PM   #52
DSM Loki
Moderator
90tsiawd
DSM Loki's Gallery
This. Use quality measuring devices. I like starrett, mitutoyo, sunnen, etc.
10HR OPR BSMR NAFPR
Old 04-14-2013, 11:26 PM   #53
90BLACKAWDTSI
Hardcore DSMtalker
I am rather fond of Mitutoyo as far as my dial bore gauges.
Old 06-02-2013, 07:35 PM   #54
4g64fiero
4g64fiero's Avatar
1997 gs-t stock
4g64fiero's Gallery
It still takes skill to measure a clearance. With just a caliper a user has stability in just one axis. With a dial-bore, a user has stability in two axes. No measuring device affords stability in all three it seems, are you guys measuring with an initial reference from the block deck when measuring cylinder bore?
How about when measuring the torqued bore of a rod journal? Even with a dial bore gauge, how do you make sure your z axis is stable?
Things like this that are immediately apparent to professionals, are not to those who have no experience with the equipment (me).
Old 06-02-2013, 11:23 PM   #55
Sean485
Senior Moderator
Sean485's Avatar
99 Spyder "GSX"
Sean485's Gallery
A dial caliper is not accurate enough for most engine assembly processes so that throws that measuring device out completely. A dial-bore doesn't matter on rotation and trying to find center you are simply looking for the smallest value to make sure the gauge is square and centered in the bore. There is some practice in precision measuring and a bit of a touch, but it is not rocket science.
You need to measure cylinder bore in multiple places to make sure it is the correct size, not egg shaped and not tapered. For anything small like a rod bearing you can loosely clamp the stem of the rod in a vice or something and then you just go back and forth with the bore gauge to find the smallest measurement, then you turn 90* or so and measure again to check for circularity.
99 Spyder "GSX"
Sean Clancy
Old 07-29-2019, 03:22 AM   #56
johnsnowkornar
johnsnowkornar's Avatar
Peugeot Coupe
johnsnowkornar's Gallery
Thanks... It is very informative.
johnsnowkornar is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
