Ok so quick run down of the car. All stock fresh 6 bolt swapped 97 gst. 2g head. Stock turbo, injectors basically everything. Removed all the emissons stuff. Mbc set at 13. Green top cas. Fiav removed. Basically all the bullshit stuff has been removed proir to the swap. Also dont have link yet but thats the next purchase.
So i have not set the timing with a timing light yet. It is going to happen though. And also i do have a slight boost leak that I'm still chasing. But .. those things shouldn't matter right now.
When i start my car it will idle fine. Take it out for a drive, stop and it will idle about 150 rpm lower then where i have it set (its set around 950). And it will kind of like pop every couple seconds. You cant hear it or feel it unless your hand is by the exhaust. Just like an extra puff of air comes out is the only way i can describe it. But it does idle lower and slightly rough. Turn it off start it again, sometimes its back to normal, sometimes its not. Car drives fine, pulls fine. Ive adjusted the timing, checked gap. Just wanting to get some ideas of what it could be. A little afraid to drive it far until ita fixed so ...
Let me know and i'll answer any questions to help figure it out. Thank you.
