Oh Where to Start- Tricky car questions - Page 2 - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Non Turbo Tech > All Things 1.8
Notices
Old 01-12-2011, 02:52 PM   #16
Katz
Katz's Avatar
1994 Eagle Talon DL 1.8
Katz's Gallery
Re: Oh Where to Start- Tricky car questions
Yeah ill get pictures of the water, and yes it sat because it overheats.
Katz is offline   Reply With Quote
Old 01-12-2011, 03:14 PM   #17
GTAhot92
Ultra DSMtalker
GTAhot92's Avatar
94 Laser
GTAhot92's Gallery
Feedback Score: 2 reviews
Head gasket for sure. If water is leaking through the head casting, sounds like a cracked head! Have you been over to www.dsm1eights.com? If a head is needed for replacement find a Cyclone head.
1994 Laser 4G37 Turbo - Tricksy
1980 Turbo T/A - Stasia
1992 GTA 5th Anniv. - Jasmine
1976 455 T/A - Revenge (SOLD)
1984 Maserati Biturbo 2.5TT - Giovanna
1989 Silverado - Shooter (SOLD)
1988 Thunderbird TC (Sold)
1990 Silverado Z71 - Excalibur
2010 Cube Nismo - Envy
1994 M3 - Faith
IG @ Blu_DeuxCoupe
GTAhot92 is offline   Reply With Quote
Old 01-12-2011, 03:18 PM   #18
Katz
Katz's Avatar
Katz's Gallery
Well what I need at the moment is, a guide on how to change it, and any hints or tips to changing them would be welcome. What all "should" I replace and what all "needs" to be replaced?
Old 01-13-2011, 10:10 AM   #19
GTAhot92
Ultra DSMtalker
GTAhot92's Avatar
94 Laser
GTAhot92's Gallery
Keep as much of it assembled as possible is the best tip. It's been sitting so long I would suggest replacing all the included gaskets anyways from the kit. SandCobra on here is another 1.8 guru, along with Mischif... Hopefully they will log in and give a few cents as well.
It's been outlined in several threads as well as one of mine but I'll sum it up for ya.
*Remove Alternator/ Power steer pump
*Remove Upper Timing Cover
*Remove exhaust manifold (should just rest against Rad Fan)
*Remove Distributor
*Remove Intake Manifold/ Throtle Body as assembly
*Remove Valve Cover
*Before Removing the cam gear set the crank and cam to TDC
You may wanna replace the timing belt while your in there. I had no need to as it was done by a motor shop for me so I took the short cut route.
*Apply Vise Grip pliers to center top of cam gear to hold belt to it.
*Remover center nut for cam gear/ let rest aside
*Unbolt head in steps followed in pattern from a manual
*Lift head out
You should now what to do from there..... Good tips are using a Phillips screw driver to get the gear/belt back up to the cam. Use Silicone sealant around the water port block off on the intake manifold. Use NEW HEAD BOLTS!!!! Apparently over on www.dsm1eights.org we had a discussion on who can pull a head the fastest and it was around 30 minutes for Mischif I believe. Make sure you check that head for cracks before reinstall.
1994 M3 - Faith
IG @ Blu_DeuxCoupe
Old 01-13-2011, 10:59 AM   #20
NCDirtrider249
Super DSMtalker
NCDirtrider249's Avatar
1995 Eclipse GSX
NCDirtrider249's Gallery
You are also running into some more problems with the head gasket being blown. With water getting into the oil, your bearings could be starting to rust, or rusting out. I went to go buy a 3000gt VR4 that had the same problem. But I took it to 3sx to have them look at it, and sure enough the bottom end bearings were on their way out.
NCDirtrider249 is offline   Reply With Quote
Old 01-13-2011, 03:19 PM   #21
Katz
Katz's Avatar
Katz's Gallery
I plan on picking up a haynes today, If I may, I would like to tell everyone about my website that I always buy my parts from. They have almost any car, and almost any part, great guys, quick shipping, bought countless expensive mercedes, BMW, and other pieces, and never had an issue what so ever. Here is a link, "http://www.autohausaz.com" they have everything. almost all OEM parts
Old 01-13-2011, 03:33 PM   #22
Katz
Katz's Avatar
Katz's Gallery
Theres no water in the oil, I havent driven it really 15 to 20 miles most sense I owned it, and no signs of water intrusion other than the cylinders.
Old 01-14-2011, 03:02 PM   #23
GTAhot92
Ultra DSMtalker
GTAhot92's Avatar
94 Laser
GTAhot92's Gallery
Wipe em down with DW-40 before putting the head back on.
1994 M3 - Faith
IG @ Blu_DeuxCoupe
Old 01-14-2011, 03:17 PM   #24
GTAhot92
Ultra DSMtalker
GTAhot92's Avatar
94 Laser
GTAhot92's Gallery
Originally Posted by SLEEPS View Post
See when I took my honey comb out, it killed my idle. Ran noticably richer. I would put it back if I still had it.
I think it might restrict the airflow so proper measurements are recorded. I noticed it's a real POS thing!
1994 M3 - Faith
IG @ Blu_DeuxCoupe
Old 01-14-2011, 04:15 PM   #25
SLEEPS
Ultra DSMtalker
SLEEPS's Avatar
93 D21 beater
SLEEPS's Gallery
Feedback Score: 3 reviews
I agree, restrict and direct the air for best possible accurate measurement. The manufactures are not as stupid as people try to make them sound.
2015 Sorento GDi. 1993 D21 beater. X
Curret 2017 Sorento GDi. 2002 Accord 4DR on coils and rally flaps.
Originally Posted by LandoAWD View Post
Forum users are generally idiots.
SLEEPS is offline   Reply With Quote
Old 01-15-2011, 06:20 PM   #26
Katz
Katz's Avatar
Katz's Gallery
OK, here is my parts list so far.
1. Nippon Reinz head gasket set part #W0133-1619589
2. OEM long life timing belt A and B
3. OEM tensioners
4. RTV gasket sealent
Where can i get some good studs, or should i just get new bolts?
I also got my haynes manual today, and I have new radiator hoses and fuel filter on the way.
Also i opened up the glove box today, and found lots of oil change records every 4000 miles but it was usually penzoil. It had transmission work done, and the man kept the car fairly maintained, that doesnt mean that he drove it right though.
Old 01-15-2011, 09:54 PM   #27
cory89
cory89's Avatar
1990 Mitsubishi Eclipse
cory89's Gallery
OOOHHH the joys of buying a used DSM! I've had to do a lot of work on mine since I bought it but the head gasket has always been fine.
Good luck with the repair, the 1.8's are pretty reliable once everything is set to go. I beat mine up pretty badly and it just takes it and asks for more. Might also want to check out the Chilton guide, it might have some better, more specific information the Haynes probably doesn't have.
If the Haynes states to use new bolts, do it. I probably would anyway but I don't know for sure.
cory89 is offline   Reply With Quote
Old 01-16-2011, 04:28 PM   #28
barkinruday
1992 mitsubishi eclipse
barkinruday's Gallery
Always buy new head bolts when you do a head gasket. I used the old ones and 13,000 miles later it blew again.
barkinruday is offline   Reply With Quote
Old 01-17-2011, 09:44 AM   #29
GTAhot92
Ultra DSMtalker
GTAhot92's Avatar
94 Laser
GTAhot92's Gallery
If your looking for studs, call ARP direct. They know thier stuff and can cross refrence you a good bolt or a stud kit. I only use Fel-Pro gaskets, I wouldn't use anything else. Also while at it, replace the fuel injector O-rings and make sure they are not cracked/ broken and your running the White/Translucent Top 210cc variations. If your looking for a bit of flash.... The N/A 3000GT's run Green Top 210cc injectors with a billit alloy style body. Soak the manifolds in some cleaner, cause they tend to get very oily inside if your not running a catch can.
1994 M3 - Faith
IG @ Blu_DeuxCoupe
Old 01-17-2011, 08:01 PM   #30
Katz
Katz's Avatar
Katz's Gallery
Alright well, I got a compression test done today, sadly the results are very nice. 100, 45, 45, 180 # 1 - 4. just doing the test caused the oil to get milky so no more turning over until the head is fixed.
Also, I will try to get some head studs and I know the subjects come up 1000 times but GTA says Felpro others say OEM I have the oppertunity to buy a upper end gasket set, this includes injector o-rings, head gasket, valve cover gasket, exhaust gasket, intake gaskets, and new valve seals. Maybe even lash adjusters cant tell by the picture but I will upload it and let yall see the set. Also the Timing belts and tensioners come in another set both A & B belts.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
