Momentary loss of power when accelerating - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com
Wheel & Tire Center
Go Back   DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com > DSM Tech Central > Help! Tech
Notices
Old 11-12-2018, 03:35 PM   #1
97GreenSpyder
Super DSMtalker
97GreenSpyder's Avatar
'97 Eclipse GS-T Spyder
97GreenSpyder's Gallery
Feedback Score: 4 reviews
OK, this is a 97 Eclipse GS-T, mostly stock, automatic transmission. For the last month, I'm getting a momentary loss of power when I accelerate from a steady speed. No CEL's, just a hesitation that is more severe the more I depress the accelerator pedal. Once the car reaches the speed I want and let off the pedal slightly, the car runs normally (I've had it up over 100 mph). I guess I'd call it "bogging under acceleration", definitely doesn't appear to be turbo lag, I'm familiar with that, I've driven the car for 11 years.
One thing that WILL produce a CEL is flooring the accelerator at expressway speed when passing. P303 reports a misfire (the engine stumbles, then recovers, running normally when I back off the pedal). Once I clear the CEL using my ScanGauge II trip computer, everything is normal as long as I don't floor it again. Could the knock sensor retarding the timing be causing this stumble under heavy acceleration? Not sure how good the octane of the gas around here actually is.
I just checked the transmission fluid, looks good. The car has 141,000 miles, and I had the fluid changed at around 98,000 (bought the car with 64,000). Spark plugs were changed about 3 months ago, using the recommended NGK BPR6ES plugs, properly gapped.
The only change that happened just prior to the issue appearing was replacement of the alternator, which is outputting about 14 volts at cruising speed.
One other odd thing- when I pull out of my driveway (cold start), the car has a serious lack of power for about 200 feet, it's hard to do the 25 mph street limit (mild uphill grade), then suddenly the turbo kicks-in and I must quickly back off the throttle. From that point, the engine's power seems to be normal, other than the hesitation. Never previously had this cold start issue, it coincides with the hesitation issue when accelerating from a constant speed.
Any ideas? None of the symptoms occurred prior to about two months ago, the stumble on heavy acceleration (and CEL) was the first to occur.
143K not-so-daily driver, now that I'm retired. Last fall had the convertible top replaced (second time since I bought the car in '07). Also had most of the body repainted (peeling clearcoat) by a first-class bodyshop. Took five weeks, for a total cost for both jobs of $4K. Car looks almost new now. BTW, damn tired of seeing the obnoxious Eclipse Cross commercials. It's heresy using the Eclipse name on a damn SUV.
97GreenSpyder is offline   Reply With Quote
Old 12-04-2018, 03:14 AM   #2
10's or bust
Plymouth Laser RS-T
10's or bust's Gallery
Have you checked the fuel pressure aND when was the last fuel filter replacement
10's or bust is offline   Reply With Quote
Old 11-05-2019, 06:38 PM   #3
cupa-joe
Ultra DSMtalker
cupa-joe's Avatar
Galant Vr-4
cupa-joe's Gallery
Feedback Score: 3 reviews
Re: Momentary loss of power when accelerating
Possible clogged fuel filter as 10's mentioned, also how old are your wires? What did you gap your plugs to?
8.5:1 Mahle/Scat | 7 blade HX40 (BEP .55 A/R) | Evo3 manifold |Cyclone Intake | SBC 2700#/4-puck ceramic | DKS 272 | VRSF FMIC | 3" Side exit | Walbro 450 | Bosch High-Z 2200cc | BR9ES @ .032" | Flex fuel (E85) | DSMlink V3 (SD)
FULL BUILD SPEC SHEET ===>GVR4 1242/2000
cupa-joe is offline   Reply With Quote
Old 11-11-2019, 08:18 PM   #4
97GreenSpyder
Super DSMtalker
Have to look into things this weekend. Plugs are the recommended NGK BPR6ES #7131 gapped to 0.044". Fuel filter replaced about two months ago, issue with sensors on auto transmission (reading the tranny line shaft speeds) finally resolved with new sensor pair installed. Plug wires probably could use replacing. A little busy this week, funeral for my wife (liver cancer, she was only 65).
BTW, I had a weird issue with my '00 Toyota Camry LE 4-cyl last week. The engine kept cutting out, losing power intermittently, and actually dying at idle. Figured might be one of two things easily checked, iced fuel line (added dry gas), nope, so I replaced the spark plugs. Yep, that was it, iridium plugs probably had only 25,000 miles on them.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
