1 - 11 of 11 Posts
I have searched and found no help.
So 1 have a 93 Plymouth Laser 1.8L automatic and FWD.
We replaced the plugs, wireset, and the distributor cap, and tried to crank it and .......
......nothing. :dunno:
What could be my problem?
This is an urgent thing to be fixed as it is my daily driver and i need this for work tomorrow.
Thank you.
An engine needs spark fuel and compression to run. I'd also try fuel filter.
To check, for spark, you can pull the boot off and rest it against something conductive on the engine, or pull out a whole spark plug. Have someone turn the car over while you watch for spark.
For fuel, just pull a plug and smell it. Strong smell plus wet = fuel.
Did the car run prior to replacing all of those parts? If so, I'd bet your dist. cap isn't oriented correctly.
Did you mess with timing at all?
you also need to ground out the spark plug itself to get it to spark. it wont do it with just a the wire connected. (i just watched my friend try to test it without knowing to ground it, thought it was funny as hell, till i felt bad and decided to help him out)
Discussion Starter · #10 ·
The car ran before and no timing was not touched.
1 - 11 of 11 Posts
