1 - 20 of 21 Posts
Dont crosspost, especially in the advanced section.
Theres no 17g turbo afaik, theres a 17c but thats it. Can you post some pics of it.
Honorary Moderator
No such thing like shabby said....
16g:
17c (only descent pic ive found):
Ah the typhoon, i seriously doubt it'll work. It probably has a completly different turbine housing.
Use the "manage attachments" to post pics, otherwise you gotta upload them to a server like www.putfile.com
the typhoon and the cyclone use the 17c turbo. Factory, they use a 10cm2 turbine housing. I'm running a 17c turbo on my car, but I'm using it with the 7cm2 housing. FP sells it as the "Frank JR.", and I built this one when I worked at Majestic Turbo in Waco.
JREPeru said:
but can i use it with the 10cm on talon
and if so what will i need and how does it run
a 10cm2 turbine housing will not mate up with a 7cm2 exhaust manifold.
No it wont.
If you're dead set on using it that's great, but SVT Rob offered some really good advice, I suggest taking it. That would be probably the most effective way to use that turbo in your application. Give FP a look and talk to them about what turbine housing's they can offer you. They know there stuff, and make a really high quality product.
1 - 20 of 21 Posts
