I'm wondering if the 90 DSMs had a different radiator or something. Just asking cause I was trying to put one in my 91 Talon and I found its a 1/4in (If not a little more) taller. (Came from a 90 GS-T, putting it in a 91 TSi AWD)
And on that note...
Is it hard for your radiator to be down tight? If so... why?
Thanks in Advance!
Shouldn't be a problem. I got a radiator from a 91 GSX and put it in my 90 laser. I held the 2 up to each other and they were identical.
This is weirder then hell... I don't understand it. I know they should be the same but this newer one from Marks is taller!!! I hope he hasn't ripped the car up to the point where I cant see if they made any modifications to put this one in...
Did you check to make sure that the radiator is seated in the bushings at the bottom of the core support. If the stubs on the bottom of the rad are not in the bushings right then it will seem to be taller.
