1 - 1 of 1 Posts
I have a 1999 Eclipse gs with the 420A 188k miles and i got it and it had 4 engine codes being a misfire and the o2 sensor i changed those and i ran great and one day the car had a cray bad misfire when i pull the plug wire on cylinder number one you can tell it's completely not firing because it doesn't change the rpm like if you pull 2,3,4 the car almost dies but one does nothing, i changed the ignition coil pack the spark plugs and spark wires twice, and it still has no fire in one and lost all of its power slowly and now will crank but not start i compression checked cylinder number one and it has 116, so it's not a bent valve so im lost now... any suggestions on whats wrong
1 - 1 of 1 Posts
