1 - 1 of 1 Posts
($2000 or Best Offer) Good Condition 1990 Eclipse GS 5 speed FWD body with a rebuilt 6-bolt 4G63 Turbo motor swapped in.
Approx 165k miles on body, 50k Miles on the motor, 3k Miles since last motor rebuild..
Engine: 12-15 PSI, Manual Boost Controller, FMIC, 16G Turbo, Greddy BOV, stock fuel injectors, upgraded fuel pump, Autometer Boost Gauge
Recently Rebuilt due to tension-er going out in April 14'. Rebuilt by Add Onz located in Allentown PA (South 12th Street). Piston heads polished, brand new stock valves installed, Head has been machined and polished, New Head Gasket, New Gates Timing belt, New water pump, New spark plugs, New Alternator, New Battery, New belts etc.. Turbo is a 16G, currently running about 12 PSI (stock) via manual boost controller.
Body: Just Passed inspection AND Emissions for PA July 2015. Eclipse GS 5 speed FWD Body in decent condition. All doors and latches functional. BRAND NEW Front Tires Installed August 2015. All Interior Features functional EXCEPT: Tachometer, Air Conditioning (Heat works Fine), Power steering (removed due to Engine Swap/No Room), and Coolant Temp Gauge.
Minor Concerns: Idle Air Control Valve may need replacing ($75) to control idle a bit better, Needs a DSM Link ECU and tune if higher boost is desired. Small Brake Fluid leak. Brake pads may need replacing soon, may need shocks soon, small exhaust rattle at around 3k rpm, No Cat converter present so please ask where to get it inspected. Inspection is due 07/2016.
Click Youtube link for Start-up and Walk Around of the car...
http://youtu.be/PRTsK3irAto
Everything else runs and operates smoothly. The car is fast and pulls hard, will not disappoint. Please ensure that if you are buying this vehicle that you at least have somewhat of a grasp of car knowledge/troubleshooting. Car must be maintained properly. .Inspected and Registered, Clean Title. Asking for 2k OBO as is... Number indicated in ad is my google voice number (347) area code, please call and leave a message, or text. You may email as well.
Payment methods accepted are either CASH or PayPal.
Test Drives Available after proof of funds only. Serious Buyers Only, I am a family man i do not have time to waste..Feel free to ask questions...
email: [email protected]
text/voicemail: 347-770-2732 (google voice number)
Craigslist AD for all Pictures: http://allentown.craigslist.org/cto/5151683864.html
Youtube Link for startup and Walk Around: http://youtu.be/PRTsK3irAto
1 - 1 of 1 Posts
