1 - 12 of 12 Posts
whats up guys...i'm in need of some opinions.....i was able to stumble on a 1G head that i plan on unsing on my 2g (stock 7 bolt bottom end)...i'm looking for opinions and advice as to what setup of springs, retainers..etc to use....i was planning on using some SS valves, with crower titanium springs&retainers....i currently have the FP1 cams which i plan on using on the 1g head (if they fit, which they should correct?)....i'm not 100% sure as to which valves to use. and weather or not i should go with the 1mm oversized valves...so can you guys please give me advice as to which setup would best compliment my setup(listed below).......
MODS : B16G turbo, FP1 cams, FMIC w/ 2.5 short route piping, FIC 650s, Walboro 255 rewired, intake, exhaust 3" turbo back, dsmlink...and other misc mods that i dont think would be affected by the head...
p.s i would plan on running a this head on a 2.3 stroker, but it won't be for a while from now, so i would have to redo the head a 2nd time, i just want something that will produce power, and airflow to compliment my 16g......thanks
For your application, the factory valves and springs are fine.
Put you money into other parts.
You will not need springs until you go to a much wilder cam...
Ask Turbo Bob about his FP2 cams.
When i was having my engine built, Polk Performance told me to go ahead and toss in the 1mm os ss valves. he said that it would help if i did mild mods like turning up the boost some with a 255 and larger injectors.
Discussion Starter #5
cool, thanks for the reply.....so i will more then likely run stock springs...with the 1mm os vavles, and some port work.....one thing i did want to ask... will the 2g cam caps fit a 1g head, being that the cams are interchangable....the head i got did not come with the caps, but i will call the guy later to see if he might have em....but worst case scenerio, i wonder if the 2g caps will work the same?
Cam caps are not interchangable. If you got a head with no cam caps its worthless. You would have to have it line honed and that will cost more than a used bare head.
Discussion Starter #7
ok, thats exactly what i wanted to know...thanks.....i really hope this guy has the caps...
Discussion Starter #8
cool so i spoke to the guy and he has the caps for me to go get.....so now its just a matter of takin the head to a machine shop and building it......
just to double check and make sure....this is what i plan on using, please comment and let me know if i will be good.....
stock springs w/ titanium retainers or stick with stock retainers??
1mm os valves
stock rockers
3g lifters or revised lifters
do you guys think i should run a multi layer HG since i will be replacing it being that the head will be off anyway??
arp bolts
as far as valve stems, guides..etc.....should i just go with mitsu oem???
1mm os valves
stock rockers
arp bolts
I always use oem gaskets from now on. I've tried a "other" brand gasket kit, and it wasn't a happy ending if you know what I mean.
Dyesin, you used the steel gaskets? I was gonna get some for when I go to put on a new head gasket. Which one busted out on you and what are you running now? Sorry admins, dont mean to jump post.
I had some valve seals go bad that weren't oem. Also, a front case gasket that didn't seal. This is why I only use oem parts from now on. I can rest assured that it was made for this specific engine model. That dsm is gone now. It had lots of others problems as well; such as overheating for no apparent reason and drinking coolant(head gasket). It also smoked upon startup and leaked oil all over the place. After all this, I bought another dsm.
Boost.
Discussion Starter #12
cool, so i'll stick with the oem stuff.....thanks for all the help guys...
1 - 12 of 12 Posts
