Would a 2.5" DP flow the same as a 3" DP if all i'm running is a 14b or 16g?
wisconsintsi said:Would a 2.5" DP flow the same as a 3" DP if all i'm running is a 14b or 16g?
wisconsintsi said:a 3" DP wont just bolt right up there will it?![]()
I dont get any boost creep whatsoever on my non-ported 14b with 3" exhaust.nukefission said:Without some porting, you will get boost creep on a 14B/16G with a 3" exhaust. Port the wastegate passage of the turbo as well as that of the O2 housing to prevent this, or get a dump tube welded on.
Something must be wrong... I have never seen that before. I'm curious why you dont get creep, any idea? Whats boost set to, cat/no cat, etcTSi said:
Really, could you please explain?V8SpankR said:2.5 inch DP are fine with smaller turbos and actually the smaller DP help faster spoolup between shifts.
