1 - 1 of 1 Posts
Hi guys I recently did plugs,wires, cap,rotor, new gaskets for the upper intake manifold, and a new gasket on egr tube flange. Upon start up it instantly through a code for TPS so I replaced that. But the car still runs terribly. It idles ok while cold but gets worse the warmer it gets and when I drive it there is absolutely 0 power. I reset the computer and drive it for 30 minutes yesterday and through 2 codes for a misfire on #1 cylinder. Before I remove the upper intake again so I can check the #1 injector, is there any other ideas of things I can check and it should check?
Thanks,
1 - 1 of 1 Posts
