Ok, a buddy of mine has a 95' gst with these mods
big 16g
wallbro 255
hallmen boost controller
3" down pipe
o2 dump mod housing
3"cat back (turbo back)
upper and lower innercooler pipe with 1gen bov
Now the problem is that we found a bunch of boost leaks, fixed the leaks and now we have boost creep
1gear 15 lbs
2 gear 15lbs then after 4500rpm it rises to 18lbs
3 gear 17lbs and climbs to 20lbs, not sure if it keeps going up or not cause we let off the gas..lol we have the boost set at 15lbs
But we figured with the o2 eliminator housing that we wouldnt have boost creep, but now we do
how do we fix this? bigger flapper? or is there an easier way around this?
thanks....
-Jake
big 16g
wallbro 255
3" down pipe
o2 dump mod housing
1gear 15 lbs
thanks....
-Jake
