1 - 10 of 10 Posts
iam helping a friend out never herd of this but he order the wrong parts. he's got a 7bolt crank and piston and order 6 bolt rods can he use the rod or does he have to can some machine work to do this and if some what needs to be do.... thanks
Banned
It will work but you will need a customing on the rod to make it fit on the 7 bolt crank. There's a here that has done this.
Well if you like it, then use it. Also, the search button helps.
You're right. Sigged it is.
DARK HORSE said:
lol i like rule #7 but just need more info on what he should do
O'reilly? Well here is rule #7. Consider this the final warning. Please post according to this...
#7 YOU MUST post in plain, discernable, correctly spelled and capitalized English! Repeated failure to do so will result in disciplinary action. Threads that contain posts with poor grammar (regardless of whose it is) are subject to being locked.
Site Administrator
It requires machine work. It's been done since the late 90's. Search.
1 - 10 of 10 Posts
