1998 auto gsx, used a 90 cam sensor, complete 6 bolt.
First all, even with the return line off the fuel rail, still no fuel comes out. I took off the other side of the rail and hit the key and fuel sprayed out. Now the fuel pump might not be perfect because the kid who did it didn't know what he was doing. Could it not be seated enough to pump enough pressure to overcome the FPR? I also swapped FPR's incase one was clogged or something.
Second issue, I'm only getting spark from 1&4. Immediately I swapped in the stock 2g coil pack and the same thing happened. I even tried the 2g power transistor, same thing. I'm lost. I just want this thing running so it can leave my drivewway.
If your not getting spark to 2&3 the car will definatly not start. I'd make sure the transistor pack is still in good shape and that the cas is in working order. Did you wire the 1g cas in right? I'd double check your wiring and go from there. Also, if the pump hasn't been sealed right and pressure can't build up the car won't start. I've had a similar problem like this, I replaced the fuel pump o-ring and all was good.
