Coil packs maybe? Spark plug wires/spark plugs? I know it may sound stupid and newb stuff but most of the time the simple stuff like this is what causes the problem. Just a suggestion though.
I don't quite follow you. What do you mean 'notorious for leaking'? The computer (ECU) on this car is tucked under the dash behind the radio. Are you saying I can pull the ECU out, take it appart, and visually see a problem? If that's the case we'll try that.OddRob said:Pull the ECU, they are notorious for leaking and causing damage. It should be repairable.
