Ran fine for years...then while driving it I started losing power and limped it back home. Car wouldn't restart until it was cold, then died when pushed on gas. Now it won't start at all...cranks and wants to catch but doesn't.
560cc injectors, walbro 255, bpre7es plugs, oversized plug wires, tactrix pro tuned (ran fine for years with tune)...anything below after 3/21 is AFTER car wouldn't start as I tried to fix it.
I have spent hours and hours taking things off and testing and retesting. I REALLY NEED SOME HELP GUYS....love this car...but its stressing me out at this point.
  • O2 sensor -Replaced 2/1/18 - replaced with another brand 4/21
  • fuel pump- walbro 255 2/18, and new 5/21
  • plug wires - 2/18
[email protected] ohms
  • fuel filter - 2/18
  • fuel pump o ring - Toyota gasket 10/21
  • fpr - 10/21
  • plugs - bpr7es-3/19, AND 10/21
-ignition coil x2 - 10/21
Primary .9 and .9 ohms
Secondary 16.94 (2,3), 16.69 (1,4)
-injector test 10/21 (all 4 tested 2.6ohms)
Ect -test plug wire 10/21= 4.71v
-test ect 1.5 @20k ohms (80degrees)
New o ring on fuel line to rail 10/21
Smelled ecu and no rotten egg smell
I'm probably missing some stuff....
Discussion Starter · #3 ·
The plan was to sell it. Yes. Ran perfectly fine, then I let it sit for a few while it was listed....then went to start it up and nada. I have thrown quite a few parts at it trying to get it to run, but im apparently not skilled enough to pinpoint the issue.
