1 - 7 of 7 Posts
Well i figured out my problem earlier that i got very few responses on.
The afc will not hold a steady throttle position except for 100%.
Its not the tps, i've tried several others and they all do the same thing. The ecu sees and holds steady at any throttle position.
If i try holding the throttle at 5% it will flutter around from 5.1-3 and slowing work its way down to 0.0%. It seems like the signal is leaking somehow. I was told it could be the ground on the afc but i've directly grounded it to the battery with no luck.
Any ideas would be great
thanks
- John
well i would think that it would be some sort of wiring issue.. i would check all of your connections and give that a try. make sure all the joints are soldered..
its soldered and not working. i bet the afc is junk.
Discussion Starter #5
Whiteonyx86 said:
try a logger and see what that tells you
read up where i said the ecu sees and holds steady throttle position.
I've logged it with tmo on the laptop and then exported it into excell and looked at every cell captured.
my money is still on a fucked up afc. Maybe i need to put this in advanced tech?
my bad i shot right past that...before you post in advanced id just try another afc thatll let you know for sure.
1 - 7 of 7 Posts
