according to the vfaq like the instructions said i used grease to pack the oil pump gears and tha space between them in tha pump housing. my question is should i do an oil change shortly after i get the car running or is that extra grease fine in tha motor...cuz it will be diluted into tha oil right? another thing...i got sum grease on tha stub shaft also..the vfaq doesnt say anything about using grease on the stub shaft..jsut oil....will everythin be fine? btw still waitin on belt and tensioner from conicelli cant wait to drive car cuz i also threw on a tubular o2 dump housing.....plus the shaft removal...and my last belt was off by one tooth...so next time i drive my car it should be a big imporvement. later--
