1 - 2 of 2 Posts
What wire on the 2G is it that I need to splice to for the O2 sensor?
hey donnie! the wire is behind/under the stero. to get to it take off the drivers side vertical panel on the consol (goes from ash tray to in front on the gas pedal). its easy to get unattached (1 screw two clips), but tough to get it out around the pedals and seat (i spent a good half hour swearing at it and the designers before i was brave enough to bend the piece enough to get out). when you look up behind the stero you will see 5 (i'm guessing at the 5, can't remember specificly) yellow connectors (these all go to the ECU), unplug the one on top. turn it so that the thing you pushed to get it out is on top. there should be three white wires in the center of the top row. the middle one is from the O2 sensor. its best to use a red (18-22 AWG) "wire tap" to tap in to it. sorry if i went over board with the answer. if you want, i'll help you out with -just let me know when. later,
PAUL
1 - 2 of 2 Posts
