1 - 2 of 2 Posts
I've recently installed a new set of KYB AGXs and Eibach springs.. I used the old bumpstops on the install, and they were pretty worn. Can the shocks get damaged using bad bumpstops? Should I go to the dealer and get new ones, or are there others I should consider?
If they're as worn as you think they are, go ahead and replace them. I'm sure you can get a complete set at the dealer. I can't imagine how expensive a few chunks of high-density foam would be. :)
1 - 2 of 2 Posts
