1 - 9 of 9 Posts
I was wondering where you guys connected the positive lead on the light of the boost gauge. I have an autometer ultra-light. Will be on a 90 Tsi. Thanks in advance.
I used the same keyed power that my radio uses. I did it that way because I was already installing the new radio.
just tap it into the positive for the cigarette lighter light.
comes on only when you have dash lights on.
yep, i used the one going to the cigarette lighter as well. that way gauges work off the dimmer switch.
to expand on what lee said: you must use both the positive and negative. other-wise it won't dim (yea, learned through experience).
PAUL
Discussion Starter · #8 ·
I will be connecting the A/F guage on the cig lighter, so where can I connect the boost gauge? Anywhere there is a light source? Any ideas, I can't think of any that would dim the light to it. Thanks again.
Honorary Moderator
I just pulled the trim from around the gauge cluster, and wired into the illumination wire going to my fog light switch, very close to the a-piller.
John Lewis
1991 Eclipse GS Turbo
1 - 9 of 9 Posts
