i just bought a cold air intake, a intercooler system &
a engine transmission oil cooler for my 1997 Mitsubishi Eclipse gsx automatic
what type of guages would i need to monitor the safety of my car now?
boost, oil pressure, volts, air/fule ratio? id appreciate any help, thank you
also, how do i read them to know if there is a problem or everything is fine with my car? any help would be nice
Boost and a wideband air fuel gauge are my two priority gauges. In your case, a transmission temperature gauge may be a good option as a third gauge.
I feel that boost , wideband, and oil pressure are a must!! I also run volts and fuel pressure. My voltage gauge actually came in handy the other day when I was having some issues. But honestly it's up to you what you want to monitor and what you'll be using the car for etc. Like I said the three I stated I feel are very important.
Discussion Starter #4
thank you guys so much, yeah, i think ill actually go with the 4 all around. Boost, air/fule ratio, transmission temperature &volts, thank you guys :)
