1 - 5 of 5 Posts
Ok, I have a 16g level 3 turbo. To day I set the psi at 17. So I took it out and nailed it, when it hit 17 psi a heard a loud popping sound. I think that it is the Bov. Should I cruch it to hold the boost or what. If I should cruch it how do I do so? SOMEONE PLEASE HELP ME
Hmmm, sounds more like you blew an intercooler hose ... have you checked those already? Does your car still run?
1993 Forest Talon AWD - modified
Don't bother crushing the BOV. If the BOV was leaking, I doubt you'll be able to hear it. If you did blow an IC hose, your car might not run depending on how bad the seal breaks. When did this start happening? You might just wanna double check all your IC piping couplings.
1 - 5 of 5 Posts
