What is the easiest way to quiet down the squeak that I hear everytime I push in the brake/clutch pedal? It's not that loud, but I figure it's worth asking about. Thanks guys.
Kevin V.
Gainesville, FL
'90 Talon TSi FWD
You can try rubbing some brake squeek stop or even some grease on the fingers of the caliper where it touches the shim.
He's talking about in the pedals themselves I think. You have to lay under your dash upside down and figure out which hinge on the pedals the squeak is coming from. Then spray some WD-40 or lithium lube in there...it should quiet it right up. WD-40 is a bit runny and sometimes does not keep the squeak away for very long, but it works :)
