shott17 said:
my car has been just losing power at times all of a sudden but just temporarily, and i dont knwo what the F to do. my oil filter has been unscrewing itself no matter how much its torqued on, and i blew the dipstick out twice this week and i have not even been getting on it. i tried cleaning up the oil under the hood and thats when i found a that i had broken the balance shaft belt and it was just dangling in there under the cam gear. it wont come out and the t/b is still in good shape, what can i do and what could the consequences be of a broken balance shaft belt?
I'm strictly guessing here- but the oil dipstick and filter both popping out of place could be from pressure being built up. The balance shaft belt basically smoothes out your engine. Which is why there is an eliminator kit for it to give you one less belt to worry about (in addition to a few extra horsepower). A broken one means trouble for the timing belt (especially running the risk of breaking it and ruining your engine).
As for the oil filter popping out and dipstick popping out being related to the balance shaft belt- I honestly don't know.
BUT!!!
Here's what I suggest you do if I were you:
1. Go
HERE and click on the ENGINE link. Scroll down about 75% of the way down and you will see the Balance Shaft Eliminator Kit. (looks like two silver rings, a small piece of metal, and a yellow/orange looking circle).
2. Once you've found what I'm talking about, order it.
2a. Order an OEM dipstick
HERE
3. Then order new belts (timing belt & accessory belts) but not the balance shaft belt since you'll get rid of it.
4. Take the car in to a shop (PREFERABLY a race/import/DSM shop) and have them re-do the timing belt and make sure your engine is running with the right timing (so the timing belt didn't jump any teeth). I work on my car... but installing the timing belt is where I draw my line (too risky).
5. Have them install the balance shaft eliminator kit along with the other accessory belts (so they don't break any time soon either).
6. New oil (I suggest you run synthetic) with a new oil filter (some people recommend the 3000GT VR4 filter you can get at a Mitsubishi Dealer). Once you've done that then pop in the new OEM dipstick and take it for a drive.
7. Cross your fingers
