1 - 10 of 10 Posts
I am going to part my 95 gsx, I would like to sell the engine and trans first. These both have around 5-7k miles and are in flawless working order. The car has a big 16g turbo on it so this motor hasnt seen any big boost yet. I would like to get $1500 for the complete long block and $1100 for the Tre trans. I have paperwork for everything.
The engine includes:
-assembled by mission machine (local race shop)
-virgin 6-bolt crank
-acl tri metal bearings (dry teflon film lubed)
-arp everything
-carillo Pro-A rods
-weisco pistons (ceramic coated tops, teflon dry film lubed skirts)
-Brand new oem cyl. head (from dealer)
-Bc sp./retainers
-fp2 cams
-arp head studs/cometic hg.
-new oem mitsu case/oil pump
-new oem timing belt/tensioner/pulleys
-all new oem seals etc.
The trans is a TRE stg 3 built 2g awd box. Visit teamrip.com for details on that. The center diff. is not welded.
Do you have any more details or copy of the reciept for the TRE Transmission?
I checked out their web site. Does this have the 4 spider gears?
Discussion Starter · #10 ·
My bad I belive its a 2.5 stg. No 4-spider. It was done in 2005. The site has changed alot since then. The subtotal on the receipt is 1475. I can scan it in if you like.
1 - 10 of 10 Posts
